BX slow blow fuse issue and part number
jackjmillerjr
BX2370
Mar 26, 2026
Georgia
I'm a novice when it comes to repairs and I'm fairly sure I need to replace my BX2370 slow blow fuse (50A). However, based on what I've read on this site, the issue may be a positive hitting a ground wire. How do I fix this issue? What is the part number for the 50A fuse? Appreciate the help.
Dustball
2016 B2650HSDC
Sep 15, 2023
500
362
Hudson, WI
From my internal notes for my B2650HSDC-
Fuse, Slow Blow 50A 17478-60080 $15
Littelfuse PAL050BP $7
Red, female terminals
Edit-
Looks like the BX2370 uses a slightly different form factor though-
Fuse, Slow Blow 50A K2771-63910 $19
Bussmann/Eaton FMX-50 $7
Bee-Positive
Nov 16, 2022
648
680
Amsterdam, NY
First thing you want to do is download the WSM (BX1870, BX2370, BX2670_Tractor Mower loader WSM) HERE. It has an electrical diagram you can trace.
Check all the connections to the battery, starter motor, and alternator.
