Need alittle help please
leonard65
B2320 tractor
Mar 21, 2026
22
10
Ok,good people, A just bought a new to me B2320. Love the tractor. Came with a FEL I would like to buy aMM mower deck for it.I am pretty versed with tractors. when a lower my 3pt I don't see anything under the center of the tractor that would raise and lower it. I hope I am not asking a dumb question. I came from a Simplicity Legacy XL diesel 4X4 thar I had for 15 years. Just wanted something a little bigger, and maybe easier to get parts for. any help would be appreciated. thanks.
11,199
Finding a RCK60-29B and all of thee linkage hardware for a 20 year old tractor is going to be quite a challenge!
The lift linkage uses the three point to lift it.
leonard65
B2320 tractor
Mar 21, 2026
22
10
Ok, makes sense. My only option may be to settle for a 3pt mower. thank you.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
696
202
Rising Sun, MD
Good Luck on finding the subframe linkage. I have a B2410 of the same vintage and wanted to put a a loader on it.... could get the loader.... but finding a subframe was not going to happen.
leonard65
B2320 tractor
Mar 21, 2026
22
10
Yeah, you know when I did some research on this tractor before I bought it, they claim the B2320 was made between 2008 and 2015. the add said 2017 which is how they are dated by the year they were sold. So I figured getting a MMM no problem, Wrong ! You guys think my rear PTO will spin a 60 inch deck ? or get a 48 inch deck? Thanks.
11,199
You can run a 60" mower.
Send a PM to @Mountainman just in case he might have one that he could sell you.
Butch
Sep 10, 2009
696
202
Rising Sun, MD
Should not be a problem at al for finish mowers. The issues usually arise if one starts using the finish mower to cut tall grass fields or worse yet as a brush hog....:rolleyes:
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
In my book you don't "settle for a rear finish mower", it's the preferred mower:) Been using different rear mowers since 2002. Side note I never mow with the loader / frame attached. The weight of the deck means a lot with smaller tractors. My Ford 1210 with 13.5HP at the PTO runs a Caroni 60" rear finish mower just fine. HOWEVER, the same tractor will not run a 60" LandPride.
I did that experiment when I had the Ford and a Kubota B7500 at the same time. Both decks mowed well behind either tractor. The Kubota handled the weight of the LandPride (but it was the max) and handled the Caroni like it wasneven there. The Ford struggled with the LandPride deck even though it wears two front weights all the time.
Donystoy
Dec 10, 2013
737
379
Binbrook, Ontario
You will be happy to have a rear mount finish mower as the mmm are a pain to install and remove. I ended up with a zero turn mower.
leonard65
B2320 tractor
Mar 21, 2026
22
10
Ok,Ok guys I never used a rear mount mower before. I don't think I will have any problem adapting. Also I fought a MMM off of my Simplicity Legacy for 15 yrs. What a pain !Will be a little different though. Now just have to find the right one . Thanks
