BX2380
Ric4364
Wilmington, Nc
Anyone mowing a small yard (1/2 acre) with a BX2380/2680? Here is the reason for my question. I'm needing a small tractor to use around our farm occasionally, mostly mowing grass, maintaining deer lanes and atv / dirtbike trails. Some light brush clearing, I've already done the heavy work with a skid steer. Due to local sticky fingers this tractor will have to travel with me between the farm and where we live 3.5 hours away. My hope was to have one machine that could also serve as my mower at home for the 1/2 acre lawn. My yard is fairly open, but just wonder if the bx will be cumbersome in such a small area (loader removed). Right now I'm mowing with a 42" lawn tractor that is ready to be replaced. We also have some landscaping projects this spring that could really use the FEL. Sorry for the long post and thanks for any options. Ric
GrumpyFarmer
5,014
IMO a BX would do just fine on a lawn and in the light farm use you described.
To me it’s limiting factor if you plan to play in the woods is ground clearance. Other than that they are real handy within it is size and weight. Like a diesel powered wheelbarrow.
I think you would be crazy to get one without a loader.
I used mine for shuttling boats (19-25’ fiberglass) in and out of barn, skidding logs, trophy care of deer😉, light fork lift work and light loader work. They need some ballast on the rear if planing to fill the bucket or lift anything heavy IMO.
Happy shopping.
Bearcatrp
Mar 28, 2023
1,309
956
Minnesota
My BX does fine mowing about 2 acres out in the country. I leave my loader on but remove the bucket. Have the quick attach. Don’t get a BX without the loader. Won’t be worth much if you try to sell it later. You can unmount it until needed. One thing about the BX line of tractors is they all have the same lift capacity.
Shawn T. W
Dec 9, 2024
703
1,323
SW Missouri Ozarks
Welcome to diesel fueled hydraulic powered tools! :)
Sounds like just what the doctor ordered!
A Sub-Compact Utility Tractor (SCUT) is a very handy tool ... Once you have one, you will be AMAZED at what you can do with it, many projects will become tractor jobs!
No it won't do the work of a larger farm tractor, or construction bulldozer, at least not in the same amount of time, but there small size is one of its benefits ... I call my SCUT a "Swiss Army Knife Tractor" as you can swap out "tools" on both the front and back to suit your needs!
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
456
530
NE Ohio
I mow about 1½ acres with a BX2380 with a 54" belly mower. I have about 20 trees that I mow around and have no problem maneuvering the tractor around them.
BTW, Bearcatrp gave good advice regarding the loader.
6,246
Neighbour bought a BX23xx ( MMM and snowblower, NO loader). he does his 2 acres just fine about 1/4 has trees..here ,there, everywhere. He's quite happy with it.
I use my BX23S for digging and moving, stuff. With SSQA it's quick to swap out bucket for the 900# pallet forks. A 'must have' in my books.
FWIW , I have R4s on my BX23S and NO damage to lawns, unless water soaked ,like springtime.
Ric4364
Wilmington, Nc
Thanks for the input guys. 100% agree on the loader. How hard are the industrial tires on lawns? Grumpy, I hadn't even thought about moving my boats around(y).
JimDeL
Aug 31, 2022
456
530
NE Ohio
I have the R-4 tires on mine. They don't seem to tear up the lawn any more than the turf tires on my old JD did.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
124
121
Lakes Region, NH
I've had a BX2370 for 12 years and mow my lawn which has several obstacles and tight spots without difficulty. It has turf tires (rear are filled) and I find it extremely maneuverable and it does no damage to the lawn. I never remove the loader but I do remove the bucket when mowing. It is generally accepted that turf tires are less damaging to lawns than R4s and also they are generally thought to give better traction on snow and ice (which may not be a concern in your location).
JimDeL
Aug 31, 2022
456
530
NE Ohio
Neil Messick did a video a few years ago comparing the difference between tire types on turf. R-4's did quite well. Check the video on Messick's YouTube channel.
GrumpyFarmer
5,014
Tread lightly (pun intended😉)…I’ve wrinkled the seat before when the boat was riding the BX down a grade and the brakes made it worse…anyway tread lightly. (Tongue weight and proper balance is important). However it much easier to negotiate a tandem axle trailer with a BX than by hand.
I have what I would consider a ‘low maintenance’ yard. If you want a manicured lawn go for turf tires. If the BX is in 4WD and you turn tight and its going to ‘aerate’ the lawn. It’s not awful but I also don’t care about my lawn. I look at dandelions as resources for my bees. In 2WD it’s not a problem at all. It’s not bad in 4WD…I use 4WD for majority but f my yard as it’s fit for a goat / hilly…I don’t use the tractor if it’s wet as it’s just to steep. So a lot of my comments are related to terrain/slope and not the machine / tires.
If you were going to use it on a driveway for snow removal that’s maybe another consideration as if want chains or not. Turf might be better on a driveway with snow than R4s IMO. In the woods. Think I would prefer the toughness / plys of the R4s. Just my thoughts.
Keep the rubber side down. ☕
xrocketengineer
Nov 14, 2020
900
880
Merritt Island, Florida
I have 1 acre and I think that the BX is great for what you want. I went "smaller" with the BX1880 because of the 48 inch mower since I have trees A/C units, shed etc. However, mine came with the smaller R1 tires that were terrible in every way. When driving on concrete they felt like square tires, the traction was terrible, they needed to dig in to actually gain traction, 4wd was needed for almost anything . I ended up replacing them with BX23 sized "off road" wheels and tires. Much better ride and traction, hardly ever use 4wd unless with the rain when everything turns to muck.
Regardless, the BX is a fantastic tool, I even put in French drain using the forks. Keep in mind on having the third function too. It is so convenient to have a grapple claw for after storm clean up.
2,927
You could order both the R4 and R3 tires and have one or the other on the tractor as needed. The cost is probably not that great for the second set of tires and wheels.
bobnic
Mar 7, 2025
124
121
Lakes Region, NH
Having two sets of tires (R4 and R3) is not going to be cheap and a bit of a time consuming pain to swap back and forth.
Alternatively he could order R14 tires which are a good combination of R3 (turf) and R4 tire characteristics. I have R14s on my LX4020 and while I do not mow with that tractor I do drive it on the lawn without any real damage and love the R14s for snow traction.
PaulL
B2601, MX5200.
Jul 17, 2017
2,774
1,774
NZ
I'd get it with turfs if you can, but if you really need the traction, the industrials will probably be fine. So long as your yard is reasonably firm. For a machine that you trailer and use on your lawn, definitely DON'T fill the tires.
bobnic
Mar 7, 2025
124
121
Lakes Region, NH
The OP is getting some conflicting info in this thread so here goes my two cents. My 12 years of experience mowing my lawn with a BX that has filled turf tires has been very good. Having filled tires helps in stability (lowers center of gravity) and provides much needed ballast for loader work although additional ballast on the three point should also be used for heavy loader work.
Ric4364
Wilmington, Nc
My thought was a drawbar and suitcase weights when using the loader. Remove the loader and weights when mowing for the lightest footprint. I'm most likely buying a low hour used. It seems like most I've seen have the R4s, so that's probably what I'll at least start with and see how it goes. Thanks again for the first hand knowledge. I've got almost no experience with sub compacts, mostly bigger tractors and skid loaders.
PaulL
B2601, MX5200.
Jul 17, 2017
2,774
1,774
NZ
I'll elaborate on not filling.
A BX doesn't have a lot of lift capacity. And it's very stable without filled tires. Unless you have a very hilly property, I don't think stability is an issue. For lifting with the loader, you can easily ballast on the 3ph. The BX front axle is quite light weight, and the front tires don't have a lot of size - ballasting on the 3ph actually lightens the load on the front axle in a way that loaded tires don't.
Since you're trailering, loaded tires are weight you have to trailer. Whereas ballast of some sort (an implement or a ballast box) you could leave one at each property. If you're using an implement for ballast, you probably had to trailer that implement as well anyway, so the ballast is effectively "for free" in terms of trailering.
Loaded tires make it harder to change a wheel, depending on the ballast it can rust your rims, and it's weight you can't take off the tractor when mowing.
Loaded tires reduce compliance / ride quality. The BX already rides really hard. If you're mowing a lot, you'll want the softest ride you can get, and loaded tires aren't that.
I realise that lots of tractor people love loaded tires. But I strongly believe (as with my comments yesterday on MMM), it's horses for courses. I always recommend to start without loading them, and then if you have a problem that would be solved by ballasting them, add ballast then. But if it works fine without, then you're way better off without. It's easy to add ballast, it's a pain to take it out.
bobnic
Mar 7, 2025
124
121
Lakes Region, NH
I'll take a wild guess here that your B2601 does not have filled tires. Somehow you have strong feelings about how a BX rides with filled tires. From my first hand experience a BX rides fine with properly filled tires (leaving the proper air space) and the added weight does not damage my lawn. If the tires were completely filled then it would ride hard because fluid is incompressible.
The OP is apparently looking at used BXs so the rear tires may or may not be filled and whatever he winds up with he can decide if it works for him or if he needs to change it.
Bearcatrp
Mar 28, 2023
1,309
956
Minnesota
I have 2 sets for my 1880. The turfs that came with it for cutting grass. Larger R4’s (for the 23S) for winter duty. The don’t make R4’s for the small rims that come with the 1880. Not exactly fun but I get about 4 inch lift with the larger tires. I don’t fill the tires. Works fine without. I remove my mower deck for winter duty. If you do this, buy the plate that mounts underneath to protect from crap that could damage underneath. Can’t remember the company I ordered it from. Someone here will post the business. Not that expensive. If I find it, will post it.
Bought one of these to help change the tires.
