g_man
Feb 3, 2023
370
1,713
NE Vermont
We had hard gusty winds Monday and Tuesday. Yesterday when I headed out to block up some wood that I pulled out earlier this winter I came upon I pine top that had blown out from an old weevil fork. It was laying in the trail and heading up to where I stash my summer implements. There's two Rear Blades, a LandPlane, a Box Blade, and Carry-All up there. Oh-no
But luckily all had escaped unharmed. A clean up job for later.
I like to cut my logs about 24' and I block them at 18"
One thing I like about this FrostBite grapple is that I can grab and firmly hold small stuff.
gg
Reactions: 18 users
biketopia
Feb 15, 2024
421
444
Warrenton VA
Jealous of you guys who burn wood and actually have trees 😆! I have 5 acres and all of maybe 3 trees, not counting the row of cedars that have grown up along the fence line/power lines. I have to really work for my wood!!
Reactions: 6 users
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,221
2,901
Near Lancaster, PA, USA
Trustable, how about a flanged bushing/bearing? Then drill the bushing for a pin. Or shorten the bushing and use a couple washers and nut & bolt.
Trustable
l2501HST
Jul 5, 2022
374
386
Oh that’s a good idea, thanks! I ended up ordering 2 from messicks but next time I’m in town I’ll pick a flanged bushing up of a similar size and that way have it on hand in case im an idiot and don’t secure it right again. That being said I’ll be running a zip tie through it so if it does come out the snowblower doesn’t fling it somewhere out of site. I’m sure I’ll run it over with the mower come spring/summer.
Trustable
l2501HST
Jul 5, 2022
374
386
gg
I’m glad that the tree missed all the implements! Also, That is a killer setup for cutting firewood!
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
Used the Kubota and the Leinbach 3-Point Crane attachment
to lower into place the base of a soon-to-be sauna.
The base is 40x80.50, 4x6 rough cut timber and plywood
construction, too heavy to maneuver by hand.
Yes, the crane was Kubota Orange when I restored it, but the sun!
Reactions: 19 users
6,872
Took down a dead doug fir at the horse farm. No drama there.
I did encounter some drama at my place when I went to grab my forks...:(
Not looking forward to untangling this one...
Reactions: 17 users
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,898
2,312
Western MT
I did the after Winter community road maintenance. I cleaned up the edges with my rear blade.
Then, I switched to the grader/scraper. First, I used the scarifiers since there were quite a few potholes. Then, put them up and ran the grader/scraper without the scarifiers. Everything was going fine until I was finishing the last pass. Both welds broke on the front blade on the grader/scraper. Oh, well, I'll add some reinforcement this time. One weld failed previously. But, I got what I wanted done, so I'm not complaining.
A neighbor took pity on me to help get the blade and mount in the bucket. I don't know how heavy it is, but it was a lot easier with help.
Reactions: 6 users
dlsmith
BX2230, LA211
Nov 15, 2018
1,341
1,007
Goshen, IN
I spent an hour or so picking up branches and sticks blown down by a couple of high wind events over the last couple of weeks. Got most of them picked up, but had to give the ol' back a break. Probably get the rest tomorrow or Sunday if the weather cooperates.
Reactions: 7 users
Windy Hill Farms
Mx5800, la1065 loader , RTR 1574 tiller , RCD1884 cutter, titan forks
Oct 7, 2024
Waymart Pa
battery change on mx5800, should I do it myself or contact the dealer ? 6 years old , stored in a warm garage on a trickle charger .
g_man
Feb 3, 2023
370
1,713
NE Vermont
I spent an hour or so picking up branches and sticks blown down by a couple of high wind events over the last couple of weeks. Got most of them picked up, but had to give the ol' back a break. Probably get the rest tomorrow or Sunday it the weather cooperated.
I see a bucket full of bending over there !
gg
That one is going to be way more interesting than the first. At least, by the looks of it, you probably won't need a saw to get the base down on the ground but the top looks like it is wedged in there pretty good.
gg
2,939
Please post a video or narrative of how you get this mess down. Is your excavator large enough to get that down or will you have to cut/pull it out.
Be safe! I would have to hire that out to someone that knew what they were doing and had proper equipment, the trees in my part of Texas are generally not that tall so I don’t have experience with that kind of situation. I do have a couple of dead large Live Oaks that need to be limbed up so I don’t end up like Governor Abbot!
matt-m
2022 B2601
Mar 17, 2022
80
437
53
Columbus, IN
Orange and yellow (rental) playing nice today. Running a line for a new hydrant. Site prep work as part of greenhouse project as a retirement gift for my wife.
Reactions: 14 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,680
4,371
PEI Canada
Did a little maintenance on the RTV.
And then this happend. What a month for garbage weather.
Reactions: 15 users
netspyder
L3010HST
Jun 9, 2025
23
49
Missouri
set 12 cabin posts. new teeth on the post hole digger, so we only broke a half dozen shear pins and one carriage bolt that the teeth mount with. but, ready for framing the floors.
Reactions: 17 users
Bee-Positive
Nov 16, 2022
843
826
Amsterdam, NY
MUD SEASON!@!@!!~
Got stuck in the mud today (sorry no pictures).
Flat ground, turf tires, FEL on, weight bucket on back, 4WD low, diff lock engaged, going nowhere. Had to fully dump the bucket, lift the front wheels out of the mud and push backwards with the bucket while slowly in reverse. Took about five goes at it to inch it out. The wife is not happy about the ruts - right between the swing set and kids pool. :mad: Drainage project is a definitely on top of the Honey-Do list now.
  • Sad
Reactions: 11 users
S-G-R
Jun 17, 2020
1,680
4,371
PEI Canada
Used the RTV to pull the little dump trailer up to the house. My stepdaughters summer wheels and the land plane were in it.
Lifted out the landplane with the L5460
Reactions: 11 users
7,305
Extended forecast looks okay. It’s about my normal time to change over.
Geddy helped.
Planning on a load of crusher run for the driveway shortly.
Reactions: 14 users
