Have you ever
5,210
Bought something that was going to ease your worries, and when you needed it, you found out, you didnt have all the parts of the puzzle. Well to day high winds power off and on several time then off! OH BOY I GET TO USE MY NEW GEN SET !!!!!! Now I had it running braking in the motor on some 110volt stuff in the garage, and I have to say it ran well. NOW like I said the power went off, drag it over to the garage door plug the jumper into the breaker box, and yes I know back feeding is bad juju, and try to plug the twist lock in. NOPE wrong twist lock, I made the rash assumption it was the same plug but nope it is an L 14-30 not the 20 amp, grrrrrrr !!! So tomorrow is a trip to lowes or home depot or amazon for a plug and the jumper is #10awg so we are good to go there. Power came back on and I am bummed I couldnt play with the new toy
  • Sad
5,210
Well Lowes didnt have the plug I need, HD didnt have one, I even tried RK and TS just on the odd chance they might have one, nada. So I guess amazon is the way to go, ahh well so much for trying to keep your money local.
3,480
skeets-
Like this?
If so PM me your address and I'll send you one.
3,480
Back at ya.
5,120
...and when you get home from the Borg you will discover you forgot to buy something you needed to finish the job....
Or you can’t find even 1 of the 9,875 rolls of electrical tape that you have to keep re-buying for every damn project!!!!!!
(until the next day when all 9,875 9,876 rolls magically appear ;) :unsure:)
GrumpyFarmer
5,029
They are always where you find them (just like morels)😉
3,480
In addition to the above listed problems, my stuff keeps migrating 150 miles from my place in the lowlands to my place in the highlands.
Generally, if I can't find it here, it's up there, and vice versa. :mad:
Needed a staple gun this past week; I have two hand operated, one electric, and a hammer tacker.
Not one is here. (wasted 90 minutes looking:mad:)
I'll lay odds they are all up north.
I must be getting senile.:confused:
5,210
You guys for got that dreaded 10mm socket, when I die and they clean out the garage I know they are going to find,,, well a bunch of them!
Spam Bot
Windows Computer
Aug 3, 2024
174
129
Austin, Minnesota/Key West FL
Get a proper main breaker lockout for your electrical panel, and wire the generator to your main panel correctly. No excuse for not doing it properly, and you may save someone's life if you forget to shut off the main breaker.
Generator Interlock Kit Compatible, Homeline 150 or 200 Amp Panels, 1-3/8 in. Spacing Between Main Generator Breaker
Questions & Answers (3)
$49.63
/package
Hugo Habicht
G1900
Jun 24, 2024
1,514
2,164
Ireland
Well, thank you very much for reminding me. I have to order some rolls of electrical tape :giggle:
Why is it actually called "electrical tape"? In the past 50 years I used it for a lot of things but I would never use it for anything electrical.
5,210
Yes Sir I have set more than one broken finger with electrical tape
Sidekick
Jul 29, 2023
1,210
1,740
N.Y,
I used 2 inch masking tape so it didn't require a splint.
