Here are some different types of undercoats but I have never used these products.With 70°F it was time to get the snow plow off and get ready for Spring
Most was done in about 15 minutes. Get Kubota out, drop snow plow, attach forks, go back in to pick RFM off shelf, take it outside and drop it, remove the forks, grab snow plow and set it on the shelf, put the bucket on and go grab chains/slings/winch to work on RFM maintenance.
Now for the RFM deck. The 7-1/2' deck needs to be flipped upside-down and set on saw horses to clean the underside. That's where the winch comes in. First, pick it up by the rear wheels and stand it on the front using the 3-point frame as a kick stand. Next rig the two front wheels with chains to the slotted angle to pick the front end of the deck. For the rear of the deck, hook a sling to the TPH frame and bring it over the deck to the winch. Snug the winch line, raise the FEL and head for the saw horses. Raise the FEL higher and then run the winch cable out to rotate it down. Went really slick and probably took longer to type this than to rig and flip the deck.
The underside of the deck already has a few different coatings so it seemed like a good idea to remove as much as possible without buying a sandblaster. Out came the Dremel Multimax and an old blade. It wasn't magical but it worked. There were sweet spots regarding the speed and angle of attack. In general about half speed and the side of the blade at about a 45° angle worked. That is being followed by a wire wheel in the angle grinder.
Now on to reading various threads to determine WHAT to coat it with. Over the last 30-some years I tried different paints, Lanox, Fluid Film, some sort of bitumen - and I'm still searching for something that's ALMOST perfect
View attachment 170868 View attachment 170869
Undercoatings from KBS Coatings - Asphalt and Rubberized
Undercoating from KBS Coatings provide provide protection in wheel wells, gas tanks, frames, quarter panels, fenders, undercarriages, hoods, decks, and floor pans.
www.kbs-coatings.com
I would suggest you use this primer. It is very hard and smooth after it cures. You might need a topcoat but you can ask them if that is needed under the mower deck. I also recommend using the cleaner and etcher that is available (supplied in tank seal kits).
RustSeal Rust Prevention Paint | Stop Rust Permanently | KBS Coatings
Stop rust permanently with RustSeal. A high-performance, ceramic-like coating for chassis, frames, and concrete. Made in the USA. Shop factory direct for same-day shipping.
