bx22D wiring
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
27
Denver North Carolina
rebuilding this tractor when I pulled fuel tank found these wires but not sure what they go to. I thought maybe seat sensor or seat belt sensor maybe. Looked at wiring diagram I see the wire ends just not what they go to.
10,382
Is there a stripe color on the Red?
The Red and Black are most likely a accessory feed.
The Blue / White is for a work light.
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
27
black stripe red wire
found this plug under dash that was not hooked to anything so the black red wire is here found the blue white wire on this bulb
3,462
1,906
The Red/Black wire is an accessory wire that is only powered when the key switch is on and is protected by a 20-amp fuse.
The Blue/white wire is for a rear work light, which is only powered when the key switch is on and is protected by a 15-amp fuse.
