MX5800 .looking for two good headlights .
Bee-Positive
Nov 16, 2022
815
801
Amsterdam, NY
Would need another part number to look up the right side.
Coleman Equipment and Messick's have new ones for $400 each.
tractor parts asap has a used left one for $180.
Didn't look on eBay
4,063
You don’t want a “headlight”… You want a headlight “LAMP”. different things…but the PN you used clearly indicates that.
The reason I mention it…is beause there are L.E.D. replacements which can be substituted for that halogen/incandescent lamp which uses less current and heat and puts out more light.
10,713
TC650-30022 LH
TC650-30012 RH
Is the entire assembly lamp (bulb) and lens
The lamp (bulb) is TD170-99010
10,713
4,063
Correct. I had read it to include those items incorporated into the item number…. (lamp, socket, holder)…. I should have Expanded the dwg and I’d have realized it included the lens, etc.
Thanks.
