KX71-3S Engine
10,273
Can I replace a Kubota V1505 -EF02 with a V1505 ES?
Your KX71-3S should have a V1505-E3-BH-10/V1505-E4-BH-1
The V1505-E3-BH-10 and V1505-E4-BH-1 are both 2300 RPM engines
The V1505 ES engine is an 1800 RPM engine.
So it is a much lower RPM / HP then what you need.
You could take all of the governor assembly out of the engine you have and swap it into the new engine and then it be the proper RPM / HP for your use.
There would also more than likely need other supporting parts like throttle plate and the such.
RHR
MX-5200 KX-71-3 ZD21F-60 Cat D5K2 Cat 324E L
Dec 14, 2021
42
TEXAS
This is the engine that is in my KX71-3S and need a new one, so I defiantly want to get the right one.
Any help would be appreciated.
