Is there a vacuum
Bearcatrp
Mar 28, 2023
1,301
949
Minnesota
Does someone make a vacuum that sucks up small rocks and debris? Would want a 3 point that uses the PTO. My 3 point snow blower blows my class 2 Little Rock’s into my grass, about 5 feet into the yard. My old ass hurt’s raking it back into the driveway. Sucks getting old. Thanks
2,900
You might look into something like a sweeper brush or a paddle wheel device. Here are the ones that fit an Echo Power head.
I know that they make snow brooms for tractors but don’t know anything else about them and their suitability to the task at hand.
I did see a yard guy use one of the paddle things to pile up gravel from a driveway so it could be shoveled out to allow for pavers instead.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,088
1,084
E.
probably not cheap and maybe overkill in size but used rear pto grain vac's are available all over. Rear mounted and used to cavuum up corn etc... out of bins, . Might be hard to find one for the size of your tractor though.
Other option could be a leaf / grass vac. 3pt mount, pto driven, a little fab work to redirect input from mower deck would be simple flex pipe fab'ed to a hand held "sucker". Wonder how it would handle small stones vs tigs/acorns etc...
Bearcatrp
Mar 28, 2023
1,301
949
Minnesota
been looking at the walk behinds too but they are munchers for leaf so the gravel would tear up the blades. From my quick searching, those yard vacs is about the only think I’m finding. Did see some commercial vacs that would probably work but not paying 10 grand.
Shawn T. W
Dec 9, 2024
697
1,291
SW Missouri Ozarks
The paddle wheels on a weed Wacker type gizmo would work ... If you got too much money in the bank, maybe this would blow them back on the driveway ... ?
10,675
No. Snow blower blows the snow into the yard that also picks up the gravel.
You missed the joke, use the snow blower on the lawn not to move snow, but to move gravel!
None of the leaf or lawn vacs will work because you'll quickly destroy the blades with gravel.
You would need a VAC truck style of vacuum.
Or something like this:
Elliott in GA
Mar 10, 2021
858
860
North Georgia
No experience, but FWIW a non-powered tractor brush attachment: ~$1,800 - goes on pallet forks
Bearcatrp
Mar 28, 2023
1,301
949
Minnesota
View attachment 170792 View attachment 170793
I like this option. Am vested in ryobi stuff so will go with this attachment:
jyoutz
Jan 14, 2019
3,590
2,692
Edgewood, New Mexico
I don’t have a snow blower, but my rear blade will also pick up gravel and move it off the road if I try to plow all the snow off the road. Now I leave 1-2” of snow on the road whe I plow to avoid disturbing the gravel. It’s not necessary to plow the road bare. Try raising your snow blower a bit.
SDT
Apr 15, 2018
3,631
1,357
Rocks?
Seriously?
6,239
Do NOT use a leaf vacuum to pickup stones from your grass ! You'll destroy the blower's impeller. Found that out the hard way. Got a deal on one,kinda worked for leaves, then tore it apart. 'rubber' impeller was 1/3rd missing, chewed.
You should be able to rent a front mount power brush. neighbour uses one every year to 'relocate' his gravel driveway off the lawn and back onto the driveway.
Bearcatrp
Mar 28, 2023
1,301
949
Minnesota
I figured that so wont be doing that.
Bearcatrp
Mar 28, 2023
1,301
949
Minnesota
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,186
2,846
Near Lancaster, PA, USA
Years ago a guy near me was out with a Shop Vac doing a swath of his yard along the road. I just HAD to stop and ask what he was up to. He told me he was picking up the little stones from the "traction material" the state applied in Winter.
Bearcatrp
Mar 28, 2023
1,301
949
Minnesota
I thought about using my shop vac but wasn't sure if it would screw it up. The brush I ordered will be here tomorrow so will see how it goes. We have 7-8 inches of snow forecasted for this weekend. Figures.
