PTO shaft with different length halves?
icehorse
L3901, box blade, tedder rake, mini round baler, drum mower, rotary cutter, misc
Aug 10, 2022
200
50
It's a long story why I'm considering this, and I find this site's server makes me type really slowly.
So let's say I have 38" between tractor and implement, and I want 4 inches of play. I understand that the standard answer is to cut down a PTO shaft so that both sides are 34" long.
But would it be okay if one side was 34" and the other side only 24 inches?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,089
1,089
E.
as long as it meets the general rules as having enough overlap when extended and does not bottom out when the implement is lifted it is OK.
generally 6" min. of overlap for a tractor of your size should be ok.
Shawn T. W
Dec 9, 2024
699
1,294
SW Missouri Ozarks
Generally the middle 1/3rd is overlapped, when in the middle of its range ...
4,081
2,777
You need to confirm that you will have no interference along the full range of movement on the 3PH. Too long and you risk $$$ damage on the tractor side. Too short or not enough overlap the pto shaft may come apart in operation and you risk damaging something.
