Which attachment
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
50
25
Va
I have a friend that just had a new spetic installed. When they cover It up. The put clay on top. He wants me to remove the clay so he can put some topsoil down. I’ve got a rear blade and a box blade. Which should I use to remove the clay? Sorry new at this kinda work. So please be easy on me. Thanks for all the help in advance
Shawn T. W
Dec 9, 2024
571
1,002
SW Missouri Ozarks
Are you talking about the drain fuel, or the tank?
How deep is the clay?
I'd be very careful driving on it ... But, the box blade will pull it off better. . .
SDT
Apr 15, 2018
3,509
1,272
Shovel.
4,846
Yeppers a shovel, you really dont want to tear things up on a system, and really top soil on top of the clay will grow flowers just fine. Just dont let him/her plant grass on it and then drive the mower over it!
Shawn T. W
Dec 9, 2024
571
1,002
SW Missouri Ozarks
Yeah, sprinkle a little topsoil of the top would be best, grass will grown in clay too
JonM
Nov 29, 2024
207
476
wisconsin
yeahhhhhh dont mess with it at all with a tractor driving on septic is how you get to pay the stupid tax and do it again. hand tools and grunt work
kcs 61
Apr 8, 2024
50
25
Va
The tank. I think he say it was about 6-8’ in the ground. Not sure how deep the clay is
6,133
you must build them different than my class 4 was 30 years ago. Since then I've driven over my bed 1000s of times with the D-14,zero problems.
6,618
edit...best advice is to leave it alone.
JasonW
642
407
Al
Shovel or mini excavator.
I just put a new system in a few weeks ago and still finishing up on it.
The top of the tank is 6-8 FEET down?
I have drove over my drain fields with my M series, I used chambers. No way I’d drive over the tank. This project was too hard to do, don’t want to do it again.
4,799
I would at least “start off” with a shovel, and see what your dealing with.
6 inchs or 6 feet?
Then depending on your skill level, you can probably decide which is best.
I do not allow any vehicles/utv’s or anything larger than a “fat human” on my tank.
But I am a”city boy” and usually take the “error on the side of caution” approach when it comes to my septic.
10,297
6 to 8 inches?
or what you wrote...
6 to 8 feet?
6 to 8 inches depends on the type and size of the of tank.
6 to 8 feet... mostly unheard of but you could drive anything over that.
I have a 1250 gallon drive over tank, reinforced tank.
My tank is 3 feet in the ground and the leach (drain field) is about 2 to 3 foot underground.
Never have an issue with working over that.
If the tank and leach field are 6 to 8 inches, I wouldn't put any equipment on it ever.
Your very liable to do some hidden damage to some part of the system.
Personal advice I would stay off of it.
Business advice STAY OFF OF IT, unless you can get it in writing from the septic installer that you won't do damage to it, and that any damage that happens is covered by them at their expense.
7,415
Others have said it. JonM says it clearly. Follow his advice.
Septic tanks can offer surprises. Few years back we had a lid "fall" in to the tank. It had never even had a push lawn mower on it. It had a few inches of cedar chips, that's all. Discovered no rebar in the lid.
6,133
It's unclear whether the OP means the tank or the bed. Usually tank has 2 access covers and you mark them 'somehow'. Near me ,owners use round patio stones, put potted plants on them.
I can't drive over my tank, it's under the addition on the house.
3,967
How LARGE is that Septic Tank..?? Will your tractor FIT INSIDE IT?
If so, it’s gonna be a Mess if you survive it.
Bee-Positive
Nov 16, 2022
612
643
Amsterdam, NY
If you're talking about the concrete tank on the left use a shovel and install risers with a lid. Easy access for future pumping. Since it's new the soil won't be too bad to shovel out.
If you're talking about the field to the right a back blade or box blade with scarifiers. If you're scraping the field be very careful how deep you go. My field is a semi-built up because of the clay soil I have, it pretty much failed the perm tests and required fingers laid in sand and topped with fill from the construction of the house (clay) and it grows grass better than any other part of the property.
Because I have a semi-built up it is not very deep and I wouldn't dig down more than 4 - 6" in my case. I've driven over it for 18 years with my BX1880 with full loads with no issues but it's a light tractor to begin with.
