Ballast Analysis
Old Machinist
May 27, 2024
723
841
NE FL
A good video explaining the effects of loader and ballast weights.
Reactions: 9 users
Shawn T. W
Dec 9, 2024
815
1,485
SW Missouri Ozarks
Excellent video! Every tractor sales person should watch it, along with ever first time tractor owner/operator!
Here is one about how filled tires effect the tractor ...
I like a lot of weight on my tractors rear axle ... I have the ability to add 275 Lbs to the BH mounting frame if it's not on, for ground engaging equipment.
Old Machinist
May 27, 2024
723
841
NE FL
That comparison with rim guard in the rear tires and no 3 point ballast confirms what the other video claims. Loaded tires, while making the rear heavier and more stable, does not remove weight off the front axle.
Shawn T. W
Dec 9, 2024
815
1,485
SW Missouri Ozarks
Yup!
And so many people claim it's all they need to have for loader work, or maybe a lightweight 250 Lb rear blade!
Another false gauge that some use is "the back tires didn't come off the ground" yeah, but if 95% of the total tractor and load is on the front axle, a axle rebuild is right around the corner, besides the tractor can tip over MUCH easier with that mismatched "balance"!
I say that if the tractor comes with a backhoe, or is an option, that's a good starting point for how much weight is needed on the back for front loader work ... While it's possible to add more weight with a BH on, it's not easy, so ... I figure the manufacturer decided that a TLB package is not going to overload the rear axle, but also takes enough load OFF the front axle ... !
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
745
1,355
Great videos. I'm much newer to tractors than most here and amazed at what seems to be a low % of the total weight on the rear axle with no ballast. A good demonstration of the effect of a load in the bucket and the of the need for ballast with a loader.
Shawn T. W
Dec 9, 2024
815
1,485
SW Missouri Ozarks
Another thought ...
Quite often we hear/read the suggestion of "put as much weight on the back as you want to pick up in the front" ... Which is basically what the first video does, and while it restored the basic 70/30 split of weight reduction ... Is the front axle overloaded at that point? Tires?
For those that have that same tractor loader combination, I'd be VERY interested in some actual numbers out of your manual ...
Like what is the front axle actually rated for?
What is the stated "lift capacity?
What is the rear axle rated for?
What are the tires rated for?
Another thing is not just the pounds/kilos of weight on the back, but WHERE it is in relation to the rear axle ... A quick hitch will push that weight back another roughly 5" ... So that same 650 pounds is more effective, then if it is "at the pins" of the lower arms ... My 5' wide brush hog is 8' long and weighs 518.4 Lbs, but my front axle is light enough with the tail wheel off the ground that I need to add ballast to the bucket! Whereas the the factory BH with aftermarket thumb is 651.0 Lbs is more balanced, and doesn't need front ballast to turn ... My homemade 707.0 Lb ballast box that has recessed pockets for the QH to go into, to keep load close and compact to the back of the tractor, also doesn't need front ballast!
This is from when I was building it, after concrete was cured, I knocked out the 2X4 spacers, so the QH could slide in and grab that pipe ...
The ballast box stays close, and the extra 275 Lbs of weight lifting plates is very close to the rear axle, and probably is only as effective as 125 Lbs if it was out at the ends of the arms, as far as "rear ballast" (to compensate for front load) compared to "rear axle ballast" for traction ... Which is the primary reason I use it for.
Old Machinist
May 27, 2024
723
841
NE FL
I've always considered a good rule of thumb is what ever the front can pick up you should try to hang off the rear or as close as you can. Rear lift capacity always exceeds the loader capacity so that isn't a problem.
Distance from the tires is also a consideration. When I made the mount for my offset sickle bar mower I weighed the front on my LX. For one to check side to side stress on the loader and for another to make sure I wasn't maxing out the tires. As it turned out I added two hundred pounds to the left side inline with the loader arm to offset 120 pounds hanging further off the right side. I DID end up with the front tires near max but I didn't have anything on the rear when I did it so I need to put some rear ballast on just to use that mower on the front. My rear tires are loaded and I have a cab so it doesn't feel like it will lift but getting some weight off the front will give me more peace of mind.
SOOO, while it's nice to have the rear ballast tucked in close it has more effect the further from the tires you can mount it. A thousand pounds four feet forward of the front tires won't be entirely offset by a thousand pounds two feet behind the rear.
11,757
I have three sets of wheel weights on both tractors and Rim Guard in the rear tires of both tractors. The M6060 has 1,440 lb of Rim Guard and 1,000 lb of wheel weights. While this doesn't remove weight from the front axle (as if it would), it does change the ratio of the load distribution at each axle.
11,757
Another thing that Tim's video might indicate is that cabbed tractors have a much better weight distribution than open station tractors. It would be interesting to see such data for all models across many manufacturers. I sure would like to have a set of scales like those shown in the first video.
SDT
Apr 15, 2018
3,694
1,418
Bingo.
Now you know why your FEL equipped FWA tractor will not back up a slight incline on crushed rock even with nothing in the bucket unless FWA is turned on or something heavy is on the three point.
GrumpyFarmer
5,217
Through some steep terrain into the mix and then how everyone handle it?
I am no mathematician or anything, but I do like ratios, fractions and percentages as a guide.
I think 60% - 2/3 weight on the rear of what planning to pick up on the loader is a good start and fairly safe for moderate inclines.
where I feel the steering get light is when I have 90% on the rear (like my BH92) and nothing in the bucket up front, then steep grades get interesting.
not sure those are rules to live by but for me and my terrains between three hilly properties, 2/3ish is what I want for ballast as a min if planning to lift near max loader capacity, and ideally the BH which is close to 90% of loader limit is awesome on flat groundnut but steering gets light on steep grades.
That math also is pretty close on B from my experience with my chipper (900lbsish) as ballast…very light steering. If need to handle a grade need the ballast box in which is a bit less at 600ish lbs.
anyway that is what works for me. Took a while to come to those ratios but thought i would share. I have loaded tires on both machines and my MX has three plates per side as well.
Hill billy hack…sometimes have to back back up the hill to be safe or vice versa depending on load and steepness of terrain.
struggle for average hill billy is I don’t weigh everything I do much less the variety of terrains I navigate, so I like ratios
keep the rubber side down!
Lencho
B7100hst
Jan 21, 2017
451
121
NM
Thanks for posting Old Machinist, it’s great to see numbers on this topic. I wish he would weigh it without the FEL As that is an attachment itself and adds hundreds of pounds to the front.
JonM
Nov 29, 2024
284
677
wisconsin
this is really more a problem with cheap chicom/korea/india like kioti tym mahindra LS etc. tractors such as those brands tend to dangerously oversize their fel with no regard to frame size wheel spacing and weight of the machine, making it super easy to get into dangerous orientations. its not as much static weight on the axles but more in stability in rolling over while moving a load even with good ballast.
while im no fan of john deere but them and kubota does a great job in sizing loaders correctly
Old Machinist
May 27, 2024
723
841
NE FL
John Deere has specific ballast recommendations in their loader manuals. I had the rear wheels off the ground a few times on my JD4310 before I added enough weight on the 3 point end. I had increased the lifting capacity of the loader but not by more than the optional loader that could have been put on it.
This page is from my Kubota manual on ballast for the LA535 loader.
Shawn T. W
Dec 9, 2024
815
1,485
SW Missouri Ozarks
This from the Kubota LA 514/724/854 loader manual ... notice the weight of the Backhoe (wish it said which model!) ... Also the word of "and" in the first paragraph ...
JonM
Nov 29, 2024
284
677
wisconsin
i
m not saying dont use ballast. my point is that on a tractor like the crappy ones i mentioned it doesnt matter how much ballast you have when the loader is at iys max its in a super dangerous condition.
kubota and deere do a good job in rating their fel for aopropruate ballast
