Adding a hydraulic top link
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
73
29
Minnesota
Seeing the cylinder only moves a few inches and no need to move fast would 1/4"ID hose from the hydraulic control valve be sufficient.
Winkles_9
Kubota L3301
Jun 24, 2021
31
21
Annandale MN
Yes, 1/4" hose is just fine. That's what I have on my top link. It is still really fast. If you push the valve and the hose can't take the flow, it will bypass anyways just like when you reach the end of the stroke of the cylinder.
6,600
That would be an excellent choice for cylinder to outlet. Bigger hoses serve no useful purpose and make hose management more difficult.
MtnViewRanch
893
351
Lakeside Ca.
I'm assuming that you have or will be getting a 2" dia cylinder?
1/4" hose by itself will not slow the cylinder. An .030 orifice flow restrictor works perfect
I recommend 2, one for each end of the cylinder.
OldcrowP51
Aug 18, 2021
73
29
Minnesota
Thanks.
I'm building a 3 spool system for my L3901 but really only have a need for hydraulic top link at this time.
1/4" hose would make a cleaner install but wanted to make sure it would be sufficient.
OldcrowP51
Aug 18, 2021
73
29
Minnesota
Thanks, I'll keep the recommendation in mind when ready to purchase and install the top link cylinder.
6,600
Thanks.
I dont think we are communicating.
I would recommend 3/8" hose for all plumbing on the tractor. Use two 1/4" hoses to connecf the top link to the couplers.
