Front Axle Support Breather plug - L2800 HST
JD1900
L2800 HST, G1900s
Aug 7, 2013
Mobile, AL
There is a support in front of and behind the front axle. Each support(compartment) has its own zerk. Yet only the front support has a breather. Are the two compartments where grease is pumped into connected, such that in either case when pumping grease through a zerk, grease would discharge from the breather(plug removed)?
Thanks
kuboman
721
I believe the reason is, the rear support is not sealed so excess grease can escape where the front support is sealed and over greasing could either rupture the oring seal or pop out the sealing cap.
8,831
Bingo! That is exactly why it's that way. ;)
