B7100 Custom Loader Hydraulics to Solve Performance Issues
ClappedOutB7100
1978 Kubota B7100, FEL, rear ballast/ball hitch mounted on quick hitch
Mar 1, 2026
Lancaster, PA, USA
Hello all, new to the forum but have been browsing it a lot since me and my roommate picked up this old B7100. We paid $3,400 for the unit, which as far as I can tell is just about as cheap as they get on the open market - but we’re definitely getting what we paid for. For starters, we (and apparently the previous owner) thought it had 870 hours on it, but the paint on the 2 in the thousands place of the hour meter had worn off…
(Pic of day we bought it)
The first issue was the loader - it didn’t work at all when we picked it up. The owner offered to turn his torpedo heater on and blast the tractor for a couple minutes to get it working… not a good sign. The tractor ran ok otherwise, so I decided it was worth buying if that’s all we needed to fix. Being new to tractors (but very experienced with other mechanical stuff) we threw a lot of parts at it before actually finding the problem.
The first thing we found was water contamination in the oil and ice in the loader reservoir screen, which explains why PO offered to use his torpedo heater. We tried to flush the system, but found the fluid was still being aerated and possibly water contaminated. Operation of the loader was extremely slow and inconsistent.
(pic of milky hydraulic oil flush from the first day we had the tractor)
Since the soft lines were also in really bad shape, I wound up replacing them first since they’re cheap enough. After we replaced them, the added pressure burst a hard line, so we had another made at a local shop. Still finding the fluid was becoming aerated and/or water contaminated, I decided it was probably bad seals in the cylinders letting water in. While resealing the cylinders was a ton of fun, it unfortunately didn't make much of a difference. It had to be the valve or the pump. At this point, I was pretty determined, so for good measure I replaced both...
(pic showing off the gross old painted soft lines and original hydraulics)
I wanted to rebuild the original Cessna units, but they were in pretty bad shape. The valve had weak springs and corrosion from all the water in the fluid, and the pump was so worn that a copper plate within had formed pinholes (explaining the aerated fluid). Doesn’t help that any parts/seals for the FEL pump are NLA. So, I got to researching to see what it would take to replace the worn out Cessna pieces with generic aftermarket parts.
For the valve, I had to learn a lot about hydraulic thread types. ORB, SAE, NPT, BSPT… my head was spinning. At first we ordered a generic valve that used BSPT, and it took me a couple of hours of research to figure out that it would be easier to just get an SAE valve. I chose one with a third function in case we want to add a thumb/grapple to the bucket later on. After getting the right fittings, installing the valve was as simple as finding some hardware and fabbing a bracket. However, this still didn’t improve the loader performance the way I wanted, so I knew I would have to replace the pump after all.
(pic of new valve vs. old unit)
I went with a Chief brand 14cc pump (factory pump is 8.2cc!) which I was unsure about using due to the added load on the engine - there was also a matter of shaft size difference, the original Cessna pump’s shaft is 9/16” while the Chief’s is 5/8”. Fitment was also a concern since there didn’t seem to be a ton of space between the loader frame and the FEL pump bracket.
After a LOT of searching and wasted time machining the original coupler sprocket to fit the new pump, I found that Surplus Center sold the “custom” sprocket I was looking for at the low price of $13. That made me feel pretty dumb. So, some new chains and a $13 sprocket later, I had everything I needed for the project. All I had to do was fab up some brackets to mount the pump using the original threaded holes on the tractor frame and we were good to go! The fitment is pretty tight, but it’s just about perfect.
(pic of new pump vs old unit)
Now, having replaced essentially the entire loader hydraulic system aside from 3 hardlines and the reservoir, I was ready to test it. Man, does this thing move now! Yes, you can stall out the engine if the RPMs are too low and you’re asking too much of the loader, but the performance is incredible for this size tractor. I have some concerns about head generated from the new pump and possibly starving the pump with the size of the factory reservoir, but in around 10 hours of operation so far, it’s worked flawlessly!
(pic of it all sorted!)
All-in, think it was about a $600 project to get a ~60% increase in pump displacement, add capability for a 3rd function, and refresh all the lines/hardware/fluid. Goes without saying that we could definitely get ourselves into trouble with the additional hydraulic power, but that’s sort of the fun of it, right?
Seal Kit: Kubota 70050-00123
Pump: Chief Group 2 Gear Pump (2PG) - 0.85 CID (14CC), 5/8" Key Shaft, SAE-A 2B Mount, SAE-12/10 Ports, CCW Rotation
Valve: Hydraulic Tractor Loader Control Valve 3 spool, 11GPM SAE Ports Double Acting Hydraulic Directional Flow Control Valve w/Joystick for Log Splitters, Tractors Loaders
Reactions: 9 users
7,220
Well done but I dont see a joystick ????
11,005
The one thing you could have added, and still can add, is a spin on filter and get rid of the restriction and poor filtering of the original screen filter.
ClappedOutB7100
Mar 1, 2026
Lancaster, PA, USA
good idea, maybe this would help avoid any potential starvation of the pump as well. I'm sure that original screen should be replaced anyway...
3,534
7,220
  1. If you use an appropriate grade oil and size the suction hose properly there is little to no chance of oil starvation
  2. If you put a filter on the suction side you increase the chance of starvation.
  3. For cleanliness purposes the ideal configuration is a tank strainer on the suction side and a filter on the return.
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
An interesting mix of tires on that little beast. Looks like it came with turfs but you swapped in ags up front. I'm not sure from the pics if that's a 4WD version but I'm pretty sure the diameters are not in the "correct" ratio. Make sure you have it in 2WD on hard surfaces to prevent binding the driveline.
11,005
They are also mounted backwards. o_O
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
129
119
Lopez Island, WA
Some time ago, I adapted the same loader to our B5100... I used a 0.37 cubic inch displacement pump since that more or less matched the original afaict output which was belted to the engine rather than driven off the front PTO. I also added a return line filter and replaced all the hoses. The loader valve I have doesn't have float; on the list of post-retirement projects is a three spool valve w/ float and a grapple.
7,220
View attachment 170633 View attachment 170634
Do I see a power steering cylinder in there?
BAP
Dec 31, 2012
3,163
1,286
Not necessarily, used to be recommended to run the front tires in the “backwards” position when running a loader on the tractor for better traction backing up in tough loading conditions. Also, some people have found that the front tires wear better in the backward position.
ClappedOutB7100
Mar 1, 2026
Lancaster, PA, USA
You are correct, it came with two sets of wheels: one with turfs from a newer B7100, redrilled to fit the 4 bolt pattern, and the original set of wheels with ag tires. The original wheels are very rust damaged... However, a few days after we got the tractor we got a ton of snow so we put the ag tires just on the front for some extra traction. Now that most of the snow has melted, we're back on the turf tires until we upgrade to some sort of hybrid/industrial tire style.
Justin670
B7100
Apr 18, 2026
Santa Rosa California
How? what part# or who makes what you are you referring to? I'm new to tractor parts and I have this same loader that I am in the process of rebuilding and updating if possible.
11,005
There are plenty of aftermarket filter bases and a filters options.
Get a filter base that has the same size fittings as the suction line and you'll be fine.
3,068
See post #6 for someone’s filter they used.
