Finished my fueling station
jyoutz
Jan 14, 2019
3,590
2,692
Edgewood, New Mexico
55 gallon tank mounted to a steel pallet, sitting on a steel wheeled dolly. Rotary pump and water block/particle filter. Easy to load in/out of the truck with pallet forks. IMG_2531.jpeg IMG_2528.jpeg
Reactions: 14 users
War Eagle
2012 B3000HSDC and Allis Chalmer 5020
Jan 15, 2017
106
24
Nampa, Idaho
Looks nice.
I have a similar pump but I get aggrevated with it because it leaks at the handle seal whenever I pump. Wish they had a better seal.
jyoutz
Jan 14, 2019
3,590
2,692
Looks nice.
Mine is a Fill-rite pump and it does have a warranty, so I’ll see.
Old Machinist
May 27, 2024
637
747
NE FL
Nice setup. I would like to get some of those galvanized pallets.
I have a 100 gallon Freightliner tank set up with the same filter and a 12V pump. I just have the fuel delivered but I haven't had as much use since I finished digging all my stumps out and sold my backhoe.
jyoutz
Jan 14, 2019
3,590
2,692
I ordered the steel pallet from Home Depot. I’m sure there are other buying options.
jyoutz
Jan 14, 2019
3,590
2,692
Whew! $137.58. I don't want any that bad.
Most of the available wood pallets are beat up and falling apart. And I figured that this was a one time expense.
4,063
@jyoutz : That’s a nice set-up…. And that’s a Very Good Filter set-up.
Don’t worry about changing that filter element…. EVER. (no joking) The amount of fuel you’ll use in your lifetime will never task that filter.
(I have mine on a 40-yr old converted propane-tank that had questionable internal cleanliness and that filter has really been Superb now for over 6 years. A tiny bit of debris has accumulated / settled in the lower “glass” …which I dumped and wiped out the glass…but the filter was clean and so I left it in place. It’s a good setup.)
Congrats.
<edit> The fuel comes out of the tank and enters the outer-area of the filter-container…allowing anything (water/debris/etc) to Fall to the bottom… then the fuel must rise to enter/pass- thru the filter-element….before exiting toward the hose/nozzle. It’s a good method.
jyoutz
Jan 14, 2019
3,590
2,692
Congrats.
Thanks for that information. I was expecting annual filter changes.
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
Ste Geneveive county, MO
I built a wooden pallet for my 100G transfer tank. It's been 11 years and it needs to be rebuilt. It sits outside all of the time, plus I didn't use treated lumber for the cross pieces.
11,692
Close to $140 for a sheet metal pallet seems like a lot. I'd rather spend $140 on steel and make my own pallet.
I've made three steel dollies, and due to my failed trailer extension, I now have a really nice platform to convert into something useful. It already has the infrastructure for pallet forks so maybe a 3ft x 8ft pallet will prove to be useful. I want to weld up a platform for the neck of the gooseneck trailer but rather than cut this up I'll probably buy more steel and raid my scrap pile.
jyoutz
Jan 14, 2019
3,590
2,692
The pallet has stamped and welded panels and is more than sturdy enough for its intended use. I bought 2 pieces of 1/4” flat steel, 4x36” last week. $30. I doubt I could buy the steel to make a pallet for $140 at current steel prices.
11,692
It's a nice pallet and I don't doubt that it's sturdy enough and that it works as intended. It would be an interesting exercise to price out steel for a pallet that meets or exceeds the one you bought. Regardless, you have a nice a fuel system for a lot less than I paid for both of mine. However, my thoughts are that given the cost of 55 gallons of fuel, within a few years the cost of the storage/dispensing system will pale in comparison to the cost of the fuel that has been through it.
I wonder if an IBC tote frame could be repurposed for this application. I have one that I got for free, but typically they're quite cheap on places like Craigslist. Just thinking out loud.
5,099
I was thinking the exact same thing.
I got a deal on some, and only paid 20 bucks a piece.
But typically I see them for 60’ish around here. (if sold as a single unit.)
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,676
4,354
PEI Canada
I like the steel pallet. I made mine from wood for my 50 gallon tank but I should of made it larger for transport stability.
