Looks like a clean tire puncture
NordTrac
MX5200HST, BH92, LA1065, SB78-PT, V-4021
Jan 26, 2025
73
223
Quebec, Canada
Had a great day logging spruce from the plantation to make way for the shop. Had my son off on spring break to help.
And then, this happens...
It's punctured through. Air is coming out. No ballast fluid in the tire.
Any recommendation for on-site repair? Any special considerations?
Will call some local shops tomorrow.
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
Wow, that would take all 50 tire plugs for now, then an interior patch or tube later, but that's going to leave a high possible contamination hole, I look forward to the other responses. Tire looks newer.
Workerbee
Zd21
Mar 1, 2020
373
251
MN
That tire will need to come off and be patched. Some mobile repair services could do it on site.
5,277
Kubota sells a “magic tire sealant” that claims to be able to stop large punctures.
Not sure if it would work, but it might be worth a try.
They “claim” it works up to 5/8” diameter ….which it appears you might be approaching.
5,277
On a side note……….
Your picture looks like me “praying to God” that I don't hit my cottage just before I cut that tree down 5 years ago…..hahahahah
BAP
Dec 31, 2012
3,163
1,286
Industrial tire plugs. They are made for bigger tires than plugging auto tires. We used to have tires on our 3 payloaders and 2 backhoes repaired that way if the punctures weren’t too large. It takes a large tool to install and it may not perfectly repair, but might seal enough to get you out of the woods.
SDT
Apr 15, 2018
3,678
1,403
Ouch.
Remove wheel tire and take to tire shop that knows how to repair AG tires.
This, folks, is yet another reason to avoid liquid ballast.
4,191
“Runs with Scissors” is a really Like-able Guy. His opinions are …well…. mostly good.
But We All have momentary failures. (my wife says so.)
DO NOT PUT ANY KIND OF GOOP in that tire if you want to save that tire.
I actually like a particular brand of goop for preventive, anti-thorn puncutes….but THAT ain’t no Thorn !”
Have it properly patched …. which no self-respecting shop will do if you place Goop in it.
Otherwise, a tube….or a new tire. Or two. Or four , since it’s 4WD and the others are worn as much as this one.
NO GOOP. Not even temporarily unless you want to complicate your life further.
SDT
Apr 15, 2018
3,678
1,403
Bingo.
NordTrac
Jan 26, 2025
73
223
Quebec, Canada
Well, after a service call (from 40 miles away), a patch, a tube and 810 northern pesos, we're back in business!
Trash Panda
L2501
Feb 18, 2022
268
261
Wyoming
Ouch.
Call me crazy, but I think it’s an even better reason to avoid sharp metal objects.
airbiscuit
Mar 18, 2021
405
463
NW WI
I agree, however...
My neighbor has a 95hp Kubota and a deer antler put a 3/8" x 2 1/2" gash in the SIDEWALL of his front tire. He got something from his Kubota dealer that looked like a grayish brown calk, and put it in the gash. I said it's tough to repair a sidewall cut like that. He said, well, it's been holding for 2 1/2 years. If I hadn't seen it, I wouldn't have believed it. I'm still on the hunt for that wonder fix.
3,534
The tire shop near me that specialized in tractor & fork truck tires (now gone) let me watch when they patched a couple of large tractor tires, one side wall, maybe 3/4", and one between the tread blocks, probably an inch plus.
First they put a conventional patch on the inside, but big & thick. (6" dia & 3/16 thk ?)
Then they mounted them & aired them up.
The tech brought out a large caulking gun, & began filling the holes with some black stuff.
He filled them a little proud, then troweled them even with the tire casing.
He said it was heavy duty windshield glue, (think semis) and after a day, it would be ready to go back into service.
Looked good to me.
4,191
4,191
In that video …they refer to him as an “old man”.
That’s hard work in harsh conditions…and he does an amazing job returning that tire to service.
He’s almost 30 yrs old.
