L3901 - slight implement offset?
icehorse
L3901, box blade, tedder rake, mini round baler, drum mower, rotary cutter, misc
Aug 10, 2022
197
50
There are times when I wish I could offset my implements just a few inches off of center. I understand that this is probably fraught with possible problems, but really I'm just talking maybe a 6 inch offset from straight back.
I'm imagining something that attaches to one of the lower link arms and provides a lower link ball just a few inches beyond the normal ball.
Has anyone seen such a thing? Or is there a better way to do this?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
996
981
E.
yes. easy to do and done all the time. I will get some pic.s for you.
depending on what you want to do and how you want to do it and your budget.
cheap and easy is adding a cat 1 draw bar on lower link arms about $50. add a ball or 2" reciever mount or whatever off set. they have locks available to stop it from rotating, etc...
or for about $80 one of these and add an horizontal offset head from a trailer shop
or if you have big bucks you can go with a hydraulic offset hitch made by someone like Ibex or handy-hitch that lets you swing your implement from your seat way out to the side to mow ditches, pond banks, near fences, etc....
so common and easy to do just pick your budget to match equipment and task.
SDT
Apr 15, 2018
3,530
1,289
Minor three point offsets can be accomplished by adjustment of the sway bars.
icehorse
Aug 10, 2022
197
50
Right! That brings up a related question. Do you think the lower links should normally have any left-right play in them or should you adjust the sway bars for no play?
icehorse
Aug 10, 2022
197
50
View attachment 170153 View attachment 170156
View attachment 170154 View attachment 170157
Sorry for the miscommunication. Not that kind of ball. On the L3901 lower link arms, and the end is a built in ball swivel that allows you to attach your implements right onto the link arms. So I'm thinking of something that maybe bolts on to the lower link arm that also has one of these ball swivels, just a few inches out.
SDT
Apr 15, 2018
3,530
1,289
Depends upon the implement.
Most ground engaging implements require some side to side movement.
Many other implements do not.
airbiscuit
Mar 18, 2021
375
423
NW WI
I have a 5' rough cut mower that I wanted ti have a slight offset with. I took off the right 3pt lift pin, and changed it from an "outie" to an "innie" (Reversed direction to pointing in). It works great
icehorse
Aug 10, 2022
197
50
What implements are you trying to offset?
my rotary cutter, so that i can mow over ditches on the side of the road,
my - not yet purchased - tiller so that I can till under electric fence lines.
JasonW
663
412
Al
Not sure if you can offset a rotary cutter that much to make a difference. Look into an offset flail mower. But you might not have enough machine weight/stability wise.
icehorse
Aug 10, 2022
197
50
If I can mow 6-8 inches outside the tire I'd be happy. And I was thinking I'd add weight on the opposite side in the FEL.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,090
2,658
Near Lancaster, PA, USA
I plan to use a blade and maybe something else offset to one side. I'm not worried about doing it via the arms. As long as they don't contact the insides of the tires why worry?
6,155
tiller may be 'side shift'. Mine does, I offset it to the cover the right tire tracks and leave the left in the ground. The left track is now the 'foot path' for the veggie garden plots,so 5' of veggie then 1' path.
4,827
Very interesting…….
This explains a lot………..
When I ordered my tractor, I specifically ordered a “draw bar”. But was thinking of something like this….for a "trailer ball”.
But on delivery day, I was so excited, I totally forgot about it.
Then I saw this “thing" laying there about the same time, but thought it was some sort of “included attachment"
So, I have one of those things hanging in my garage, and I have no idea why they “gave” it too me.
I tried putting a ball on it, but the damn thing just keeps “swiveling around" :ROFLMAO:
So how does it work? I still can’t wrap my head around it…………..
airbiscuit
Mar 18, 2021
375
423
NW WI
You could also get Offset 3ptlift arms, and make one an "innie".
2,710
Very interesting…….
Those were designed (mostly) for pull type implements that usually had a clevis style hitch as shown here. You can see why that design of drawbar worked well for its intended use.
10,351
Very interesting…….
Add one of these two designs to it and it will become useful!
10,351
NO you can not off set the three point arms that much.
You will do damage to the system evening trying to do that.
Get implements that are made to offset.
MapleLeafFarmer
Dec 2, 2019
996
981
E.
Very interesting…….
on that draw bar if using a ball they sell "locks" for the ends. Not sure if locks is the right name but its what we call them. Locks not needed though if trailer or implement has a clevis connection.
Like most farm yards we probably have a dozen or more of those drilled drawbars kicking around. they last forever. Used to be standard use on all farm yards as remember we really didn't start seeing 3pt lift systems on the back of our tractors till about 1950's or 60's. Before that tractors had 2 point lift systems and all had these bars. So in the 60's we all used them and into the 70's and 80's as well if running older equipment that did't yet have the 3pt rear lift systems. They last forever so any yardsite that operated a farm pre 60's used them daily. Still have some use but the 3 pt hitch system killed off the 2 point as far superior.
