G1800 will not turn over
cwhiley
G1800
May 5, 2024
United States
I’ve got a g1800 with 884 hours in it and it will not start. It used to be intermittent but it’s gotten a lot worse. I’ve not been able to start it all now in about 6 months. I just hear a rapid clicking but it will not turn over. I did try shunting the 12 volts straight into the starter bypass the starter selenoid and the starter spins but it still won’t turn over.
I’d really like to avoid a $500 something bill at the dealership…but I don’t know what to even look at. I did also short the safety switch on the seat with a wire but it made no difference.
I do know how to use a multimeter to check voltages and resistance ohms but I don’t know what to look at.
If anyone has any ideas to try explained very simply I’d really appreciate any help you folks could give.
Thank you so much!
6,310
1st step... get the wiring diagram for it ! usually found in the WSM ( WorkShop manual), though www.kubotabooks,com don't list one.....
Without that you can spend hours tracking down the faulty 'safety' switch or 'interlock' switch that is preventing the starter from spinning when you turn the key.
Hopefully someone can post the diagram here for you.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
What do you mean by "starter spins but it still won’t turn over."?
I interpret that as the starter solenoid not engaging the pinion into the flywheel.
Did you short the 12V to the fat rotor current contact or the small starter solenoid contact?
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
There is three safety switches (brake, pto, seat) that affect the starter through the combination box.
Often the relais in the combination box are burnt out, leading to the starter working intermittently and then not at all. My tractor had that problem at 6000 hours, yours seem a bit young for that but it is starting cycles really, not hours.
Also it could be the start switch contact itself.
Click on the envelope, top right corner of the screen.
cwhiley
G1800
May 5, 2024
United States
I mean I can hear the starter spin up but nothing else happens. Just a whirring starter. I shunted the connection on the bottom of the assembly that connects to the battery up and over to the top. Honestly no idea what I’m doing but the starter definitely spun up. I couldn’t sit on the seat to do this so I shorted the seat sensor with a wire and I pushed the brake pedal down.
cwhiley
G1800
May 5, 2024
United States
yea I’ve read about the combination box and suspect that $330 part. 🤦‍♂️
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,616
You need to do some actual testing. Find out what voltage is getting to what terminal at the starter.
You will probably need an assistant to turn the key while you take voltage measurements.
11,150
First: You simply jumped the starter wrong, you need to jump from the large terminal with the battery cable to the small terminal usually with a spade terminal on it.
Do that with the key on and see if it will crank and fire, that will tell us where you need to go next.
lmichael
Kubota G2160
Apr 23, 2021
851
440
Rockford IL area
Kubotas have very convoluted circuitry to the starter. Roya PIA IMO. Too much current trying to get through microswitches. You can likely clean likely clean every contact and connection, relace all the microswitches and still have the issue. Likely a helper relay will solve all your issues as it did mine.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
Yes, I had that problem and built my own combination box electronics: Link combination box electronics
But lets diagnose the problem first, there still is the starter solenoid and the three safety switches to check.
Did you click on the envelope in the top right screen corner?
pigdoc
G1800S L2500
Aug 19, 2022
403
350
SE Pennsylvania
On my current G1800S, I have had a long-standing 'problem' on starting.
There is also a start-safety switch on the brake pedal. If you don't have the pedal locked in the full down position (fully applied), starter will not energize when the key is turned.
Full down: If you gently hold the brake pedal lock while you push the break pedal down, you will feel three detents. You have to keep pushing the pedal down until you feel 3 clicks in the locking lever. Then, the starter cranks, even if the battery is too low to start the tractor.
So, check the wiring to that brake pedal safety switch.
-Paul
PS, I haven't yet looked to see if I can adjust the brake pedal safety switch. That's on the list.
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,616
The microswitches carry very little current. Yes, they are potential failure points, but current is not the problem.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
They are not microswitches, see link in post #13. And the current through the switches is very small. The starter current is going through a power relais, so is the stop solenoid current.
11,150
Switches feed the box it's signals, right? ;)
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
That is correct.
And you said in your post #8 to check the starter first and work from there. But the original poster has not come back after that; I hope he has not gone on a shopping spree with expensive parts :oops:
11,150
Yep his problem could be a multitude of simple and cheap fixes.
I worked with a local guy that kept insisting that every part was bad and after $1000's of dollars on parts later it was a ground cable bolt, which I had told him several times to check and he kept poo pooing that idea.
The real funny part was when he wanted me to buy all his used parts, and of course he wanted new prices for them, "because they were know good parts" I respectfully declined.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
I have seen an extra relais in front of the starter a few times, mine had that too, but I think it is only covering up a problem with the relais in the combination box which will fail later. The extra relais should be put in long before the problems start, but who would do that?
One guy here (do not remember the thread or who it was) cut a hole in the plastic of the box to get at the relais pins for desoldering and replacing the faulty part. I think this is a simple, cheap and effective repair.
