g_man
Feb 3, 2023
342
1,540
NE Vermont
This morning I completed the swap of Faster couplers for Summit Hydraulics 1/2" Ag couplers on the M6060.
From this ...
To this ...
Very nice. Neaty and simple !! So am I understanding your set-up ..... Two levers, one each for top and tilt on the two top rear remotes. The third rear remote (Bottom, but not connected in pic) lever has 4 buttons to control the four summit electric valves ??? Maybe a pic if you get the chance.
gg
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,585
3,965
PEI Canada
@S-G-R, nice video there. I always like the sights and sounds of a tractor working, and the plume of snow is the icing on the cake. We've had so little snow here in NW Montana. It sunny and mid 40s today and feels like spring is here.
I have an SB1574 blower but it looks small compared to yours. 😂
It was a bit of a challenge keeping everything going and holding the phone to record 😆
I'm not sure what the difference is between the two blowers. Kubota Canada has no info published for any of the three I had/have.
Shawn T. W
Dec 9, 2024
526
958
SW Missouri Ozarks
What brand top link did you go with?
I'm sorry for the delay, as I wasn't sure ... All I could remember was I got it from my local Massey Ferguson dealer ...So I was going to go out to the barn and look, but then I forgot ... And now I'm gone back on the road and probably won't be back for a couple of weeks ...
I do know that in order to get the length I needed we had to order a CAT2 on both ends, and I then used bushings to bring it down to the CAT1 as my top on the tractor is CAT1 and the QH is also ...
10,544
gg
You nailed it! Who says a picture is worth a thousand words? You did it in less than 50! 😂
10,544
Thanks for the info ! - Wow, I didn't realize what new tractors looked like from the operators seat. A real eye opener for me. Thanks again.
gg
My M6060 is four years old now, but the M7060/6060 model is rather dated, although I very much like the interior and don't have an issue with it. I'm not sure when the M7060/6060 was introduced but it's at least 12 years old now. I thought that the M4 was supposed to replace those models but it doesn't appear to be the case yet.
I don't plan on replacing either or my tractors, but it will be interesting to see what's available in the coming years as the bells and whistles on the new L70 models start to trickle into other new models. Features that I'd like in my MX and M include a swiveling seat and cameras front and rear. The latter are fairly easy to add via a screen and cameras.
BruceMc
BX25D LX2620
Sep 27, 2014
40
86
Fairbanks, AK
The inspector approves last night's cleanup. I've been plowing the same area since 2000, and this is the first year I'm getting to the limit for stacking snow.
Reactions: 16 users
Papadiver
BX2380 FEL, MMM, 3rd Valve, Grapple-Grand L4060
Feb 10, 2019
118
119
WV
No worries! Thank you.
Ron
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,060
2,586
Near Lancaster, PA, USA
Only had a few minutes of seat time but the weather was nice enough to get the Kubota up to the house and replace the headlight bulbs. The left side wasn't working. Assuming it burned out i decided to just get two LED's and replace both. Some disassembly made it easy and thankfully nothing had any corrosion to deal with. It was back in the shed before dark, so i don't know how well they'll work.
Reactions: 6 users
5,644
Did several little things but no pics.
A few days ago, noticed about 6oz hydraulic fluid on the floor directly under the rattle vent on the bell housing. Not great, but I’d been swapping stuff on both front and rear remotes earlier and moving the tractor around while doing that. The Pioneer quick connects usually dribble a little when disconnected, so a bit on the floor isn’t exactly odd after hydraulic disconnection but this seemed to be too much. Depressed the rattle vent thing and nothing came out. Cleaned the floor and left it.
Next morning after nothing but sitting overnight, a new little puddle in the same place. Great. 608 hours, out of warranty, and it’s looking like the HST is leaking into the bell housing. Checked the engine oil. Not gaining, so at least that was good. Still nothing coming out when manually depressing the rattle vent.
Recalled I changed the HST filter 8 engine hours ago. Haven’t had a spin on filter of any sort leak since I don’t know when, but figure it’s worth tightening a bit more and taking it off to check the seal for damage or double seal or other issues if a little more torque doesn’t fix it. It’s really not all that close to where the puddles were, but I know sometimes fluid runs a ways before dripping off and that’s the only thing out of the ordinary recently. Tightened the filter an additional 1/8 turn, which made it a good bit tighter than normal.
Two days and 4 engine hours later, no more leak. Very thankful the tractor doesn’t need to be split to replace a seal. Not looking forward to removing the HST filter next time it needs changing.
Reactions: 10 users
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
305
192
NH
Your lucky!
Hopefully you will never have to, but I admitted to myself that after seeing that puddle, that at 800 hours the seal needed to be replaced.
Checked a couple of dealers and one of them was able to do the job without removing the cab. Saved me quite a bit in labor.
mdhughes
L3901DT
Dec 10, 2014
1,427
1,409
Ste Geneveive county, MO
Yesterday I did something I haven't done for years, I used the bucket on the L3901DT to move a couple logs.
I needed to get them out of the way so I could put the grapple on the tractor. I moved 3 grapple loads of logs. This is just one of them. I have been cutting down Blonded Ash trees.
Reactions: 7 users
10,544
The local Kubota dealership moved late last year from 3 miles from my house to much closer to the center of town. I stopped by the new location for the first time this morning to pick up some UDT2 and to check on the ETA for the new QH20. I was given a Kubota hat for showing up. 😂
I was surprised as to how much inventory they have including an M4 and M5 and a bunch of excavators. There's a KX057-4 coming in on trade that has ~1,400 hours on it so of course I had to look at the KX057-05 on the lot (there were at least three). All I can say is 😲😲😲 ... what a beast of a machine, and the engine compartment is a work of art. The mini is much larger than I remembered.
As for the KX057-4 vs. KX057-5, well, at less than half the cost of a new machine, the used one sure is tempting. The dealership is going to get back to me next week once the trade in has been finalized. I'm really not ready to buy something but if the deal is right I might just have to sell a kidney or two.
Reactions: 7 users
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
109
192
NW Arkansas
Mucked out the straw (and weekly chicken shit) from the coop from the cold weather. 78 degrees in late February in Arkansas 🤷🏼‍♂️nice day to make the wife happy.
May be just a hydraulic wheelbarrow but beats carrying it down the hill to the burn pile by hand. Happy chooks, happy wife, happy life…
Reactions: 11 users
mdhughes
L3901DT
Dec 10, 2014
1,427
1,409
While out in the woods felling Blonded Ash tree today, I came across a Hickory that had a hole in the upper part of the tree. I decided to fell it also. Looks like it was the right decision. I used the L3901DT and grapple to move the logs to our splitting area. The smaller log is a dead Oak that I also fell. I cut all of the trees I fell today into 60" logs. The path I made down to the area the trees were was wide enough for 80" logs. I made the trip 4 times with an Oak and a Hickory log. It was about 1/4 mile trip one way.
Reactions: 7 users
johnjk
Apr 13, 2017
1,735
2,011
West Mansfield, OH
Wel. Went to start up all the equipment his morning and noticed blue fluid by the wheel of the B3200. Looks like I have a leak around the rim. Now I have to figure out out how to get all the washer fluid out, clean and reseal that rim.
  • Sad
GrumpyFarmer
4,777
Installed a new battery and brought the evaporator up the road and set it a little closer to the wood pile. I suspect I am going to strike a match first thing in the morning. (Approx 60 gallons filtered today which is enough to make a mess)
Reactions: 9 users
