Leaking hydrostatic drain plug
bobaloo22
B7800 hydrostatic
Jan 30, 2026
Central Virginia
The right rear plug on my b7800 has a small drip, about one drop every 36 hours. I pullEd The drain plug and the washer is steel with an o ring, o ring was shot. Is this the factory Kubota washer? It’s been several years since I’ve changed the hydraulic fluid and can’t remember. Thanks for the help,
Bob
6,519
Bob
That sounds like a standard elastomeric BSPP sealing washer. Nothing Kubota specific about it. If the rubber portion is damaged you need a new one.
bobaloo22
B7800 hydrostatic
Jan 30, 2026
Central Virginia
Yes, but I was wondering if this is a standard kubota item. I can get 10 for the price of one at the dealer. I was told that it used a copper crush washer but I don’t believe that is correct.
bobaloo22
B7800 hydrostatic
Jan 30, 2026
Central Virginia
I’m sorry but I thought the thread title saying leaking hydrostatic drain plug would be enough info for the location of the leaking. I’m just trying to clarify if this is the correct washer. i know there are three drain plugs and it’s the right (starboard)one. Yes Wolfie that appears to be the exact one that I have Thank you
6,519
All you need to know is what size pipe plug.
