L235 front driveshaft
Mike66
9
Castor,alberta,canada
Hello all. I am knew here. I recently got a l135 1982 model 4 wheel drive. Front drive shaft coupler was changed by previous owner. But it stripped out and also the splined shaft into front that driveshaft connects to is stripped. Is there a work around this issue or am i dead in the water for parts? I found a picture of part but thats about it!
10,989
I don't know of any logical work around to it other than replacing parts.
Send @007kubotaguy a PM and ask if he has any of the parts you need.
4,191
pigdoc
G1800S L2500
Aug 19, 2022
401
347
SE Pennsylvania
Any idea WHY the front driveshaft coupler stripped out?
Asking because I had the same issue in a tractor I purchased.
PO (previous owner) had installed front tires/wheels that were too large, causing a mismatch between the tire ratio and the tractor's gear ratio. Splines on shaft were also stripped. Splines on front pinion were badly worn. Got my eye out for a front axle for parts with a good front drive pinion...
Here's a pic of what I found (front drive pinion):
-Paul
