drawbar extension
ldozier
Kubota 2013 MX 4700
Apr 11, 2018
Dolores
My MX4700 drawbar is too short and too high for standard farming tools such as a hay baier. I find ther is a hammerstrp bolt on but I can not find one formy MX 4700. Has anyone got any suggestions
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,896
2,311
Western MT
I don't know how long you need, but there seems to be a lot of different lengths and types online.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,091
1,089
E.
ask your dealer to spec out the hammerstrap with part Part # 35080-29720. I think you might find this will give you about a 1 1/4 drop without spacers. Should be able to add spacers if more drop needed.
BAP
Dec 31, 2012
3,124
1,258
You sure that your drawbar is in correctly? Manufactures make drawbar lengths to Standards based upon a certain distance from the tractor’s PTO shaft. If the drawbar is in backwards, you probably can’t get the correct distance. How is your drawbar too high? A tractor like a MX4700 is a small tractor for a baler compared to what most people run and has short tires compared to 100+ HP tractors.
6,170
There’s an optional drop drawbar that’s offset to increase the PTO to drawbar gap for the L4701.
I don’t have one and a brief search didn’t reveal dimensions. Also didn’t see a drop drawbar offered for the MX4700. Might be worth checking with your dealer to see if there’s a drop drawbar for the MX4700, and if not, whether the drop drawbar for the similar size L4701 is compatible.
ldozier
Kubota 2013 MX 4700
Apr 11, 2018
Dolores
My drawbar is correctly installed. I use an old(1965)New Holland 275 baler that is no problem for the tractor. I use an after market drop drawbar but it is really too lightweight. It is bent
ber: 11653"]
[/QUOTE]
11,725
You could weld on a plate to the end of the drawbar and then you can run multiple configurations. I did that for both tractors. The drawbars can be flipped over to change the height of whatever hitch I want to run.
In full disclosure, I also have the original drawbar for the M6060 since it works great with the Land Pride RC3712 folding cutter. I actually got that for free when I bought the cutter since I'd already cut up the factory one.
MX6000
M6060
