L245DT hydraulic filtering
cummins90
CT
I have a FEL with a hydraulic oil spin on filter on the outlet side, is the case screen still needed? I get icing in the winter even with a fall flush and fill.
7,074
Yes. JFYI, if the spin-on is on the tank return it only filters oil when you are operating the loader. The sump strainer filters full time and keeps "chunky stuff" from getting into the pump
cummins90
CT
Then its settled, FEL filter stays in place The screen filter remains out cause all im doing with it in is cavitating the pump and subsequently getting nothing done.
7,074
Without the strainer you are exposing the pump to a lot of particulate contamination. Maybe rhe better course of action would be to fix the underlying problem.
