M Series Rear Window
Jerferrera
2008 m108x, 2010 M135X, 2013 M110GX, 2015 M110GX, 2015 M126Gx
Jul 17, 2015
15
Ontario canada
Hi, I am wondering if anyone has came up with a homemade or store bought product to hold the rear window open on the M series rear window... we use our tractors for snow removal and would like to crack the window open a few inches. TIA
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,911
2,323
Western MT
How about a plastic clamp that you pad? However, if the window isn't designed to stay open, you might to check to see if it will slide off the hinges or not.
On second thought I think I'd make sure it can lock open, so it doesn't vibrate so much.
4,079
11,757
Can't you simply open the side windows? My M6060 has a large rear window and two rear side windows (see below).
11,757
My MX rear window has a feature to crack the rear glass and lock it in place via the latch. When I get back I'll look and see if the MX latch would fit the M glass. Maybe there's a way to swap out your M rear latch for a part from another model.
Jerferrera
Jul 17, 2015
15
Ontario canada
Thanks. our tractors don't have side windows. pictures would be nice. online the latch look to have same mounting holes
11,757
I'm back in MT and will look today once I get the tractors fired up for snow removal. I have the original rear glass out of the MX (I uprgraded to rear defrost) and I also have new rear glass with defrost for the M so can look at the hole size and placement for the latch and see if it might be an option for you. I'll take photos and post them later today. And even if the MX and M latches are interchangeable, this wouldn't be of help to you if your M tractors don't have the same holes as the M6060/M7060.
Which model or models in particular are you wanting to crack the rear window on?
11,757
@Jerferrera, I took a closer look at the rear windows of the M6060 and MX and there's good news and bad news. The holes in the glass are spaced the same at 60mm but the MX has a much more elaborate system to open the rear glass a little and secure it in place.
I think it would be possible to modify a tractor to work with the MX system but I can't say if the view is worth the climb. The MX doesn't have rear side windows so it makes sense that it has the rear latch feature.
M6060 latch "plate"
MX6000 latch "plate"
M6060 rear window latch
MX6000 rear window latch
MX6000 rear window latch locked in "cracked" mode
MX6000 rear latching mechanism
Jerferrera
Jul 17, 2015
15
Ontario canada
M6060 latch "plate"
wow... that's what I'm looking for... I just don't have the mounting pieces welded to my frame. I could add them tho. not sure what Kubota wouldn't add this to all tractors
11,757
The assembly shown above isn't particularly expensive, maybe $100 all in, and you wouldn't have to weld on the three tabs shown below. You could make up brackets and bolt them to the frame if you added rivet nuts or similar. Lots of ways to retrofit the necessary interface to work with the half lock bracket.
The rear window latch in the MX and M are the same so it's possible that your Ms use the same latch too. You could order the half lock kit and see if you can make it work. It's a really nice solution that Kubota came up with for the MX which as I said doesn't have the side rear windows that the M has so it's the only way to vent the cab via the rear glass.
