Best Source for New Tires ?
Noyrt1
L2500 Tractor ; 8N Tractor; Bobcat 773 ; Typhon 'Tyrant' Mini Ex
Feb 11, 2026
Georgia - USA
I purchased my tractor used recently and all the tires are dry-rotted and cracked from sitting too long. They are holding air, but look really bad cracked on sidewalls. Need to replace them all. Curious for opinions on the best source to buy a full set. (L2500 4WD) Good quality and fair price? Thanks.
6,278
probably far cheaper to buy them as 'tire on rim' from the 'whole goods' counter at local Kubota dealer.
FWIW the rear tires for my BX23S list for $500, so I buy SAME tire, mounted on a new rim, with new valve and already has air in it for....... $340.
I can't explain WHY they're so much cheaper when you get everything.......
jyoutz
Jan 14, 2019
3,622
2,716
Edgewood, New Mexico
Besides the dealer you can also check with any large truck and industrial equipment tire dealer. They can usually source tractor tires at a price less than the dealer.
3,821
2,379
If your wheels are in good shape, you'll save by ordering from a tire shop.
If you need wheels, better sit down. There are 2 R1 choices and one is discontinued. No tire/wheel assemblies. Make sure front and rear are coordinated in case you have to change rear size, they may need different size fronts.
You might see if a current model, L2501/2?, matches your wheels. Don't forget to check the circumference ratio.
Post brand, size, and type of your existing tires and someone might give better advice. Do you want to stay with that style, if you want different now's the time?
pigdoc
G1800S L2500
Aug 19, 2022
401
345
SE Pennsylvania
Are you located in an agricultural area?
If so, you might be able to find a wheel and tire shop that's not 'proprietary'.
Here's the one I use:
Wenger Systems | (717) 656-9876 | New Holland, Pennsylvania
I realize you're not near this shop, but you can call them up for a quote, to get a starting place on price.
These guys have an inconsistent stock, because they tend to load up on dealer close-out surplus (read: CHEAP!).
I have oversize tires on my L2500, both front and rear.
For an R1 tire, you can't beat the Galaxy Earth Pro series, IMO...
I think that Kubota supplies Galaxy on certain 'tire on rim' sizes...
Mind the F/R gear ratio, when picking tires. Or, do not deviate from the OEM sizes.
F/R gear ratio on the L2500 is 1.6363.
If you're going to run an FEL all the time, you're going to want ballast in your rear tires.
Also, Galaxy is a subsidiary of Yokohama Tires.
Japanese tires on a Japanese tractor.
It's a natural...
-Paul
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,934
2,332
Western MT
This might help. Apparently the prices vary depending on who you buy them from at the dealer.
Sawdust&Shavings said:
From the tractor salesman at your Kubota dealer…not the parts department. On my BX-1870 I have two sets of mounted tires from my dealer, one set of R1 agricultural tires and one set of R3 turf tires. The additional set of mounted tires from whole goods was ~$500.
BAP
Dec 31, 2012
3,156
1,282
What size do you have. A local tire shop that has 6-8 places, that deals in car, truck, big trucks, industrial and tractor tires, list the 11.2-24 tire starting at $247 to $283.
John T
2017 BX23S
May 5, 2017
1,290
813
under a rock
True.
I got a sweet deal from the local Bota dealer on 4 brand new "take-offs" rims/tires.
NoJacketRequired
May 25, 2016
444
Ottawa, Ontario
If you are looking for turf tires, I've recently posted my story about the Kubota OEM "whole goods" which I purchased for my B-series.
To keep it short, it appears the "tire on rim" deal might not be so good after all. The tires are "Litefoot" brand and seem to be too light-duty for the job. I'm experiencing air loss through sidewall cracks at molded-in printing and the base of tread blocks. Some suggest overloading but the reality is that I haven't lifted anything of significance with the FEL since these new tires went on. They are pretty much junk in my opinion.
I'm hoping the new tires I'm installing, Galaxy Mighty Mow, 6 ply (rather than OEM 4 ply) will provide better durability.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
696
202
Rising Sun, MD
Well... I have a B2410 2000 vintage. I needed front tires so I went to Kubota. Tires discontinued.... like not being manufactured any more.
I have a 4 wheel drive where the back tires have to work in synchrony with the front tires. Kubota left me hanging without a straight swap out option. WWW.Millertire.com bailed me out without breaking the bank. Might try giving them a call.
Scm
BX23S
Sep 28, 2024
402
402
Missouri
Last year I had front tires mounted to my BX23s rims for $138 each. simpletire.com has the same tire rim combo for $82.96. & free shipping. Its the foam filling that is expensive.
NoJacketRequired
May 25, 2016
444
Ottawa, Ontario
Time for a follow-up post...
The Galaxy Mighty Mow tires are now installed on the front end of one of my B7510's. My first couple of hours of snowblowing (front mount B2782 blower) included the usual transit down our gravel sideroad between laneways.
WOW what a difference!!!!
In retrospect, it is now clear to me the "Litefoot" tires sold to me by Kubota as whole goods were, right from the get-go, underqualified for the job.
The Galaxy Mighty Mow tires are 6-ply rated while the Lightfoots are 4-ply rated. The difference between them in terms of tractor handling, particularly a full forward speed on the road, is night-and-day. The Galaxy tires provide rock-solid handling. There's none of the "bobbing up and down" that I experienced with the Lightfoots, no need to slow down when hitting a pothole caused the tractor to start rocking back and forth.
I simply can't believe the difference in stability offered by the Galaxy Might Mow tires. I don't think I'll ever recommend buying Kubota whole goods tire/rim combos if they continue to be supplied with Lightfoot tires. The Galaxy tires are seem like a very significant upgrade in stability. I can't wait to see how they feel when using the front end loader as the Lightfoots always felt "squiggly" under load.
hemiguy
B6100D
Feb 26, 2026
Hi, new member here.
I bought two 8.00x16 ags last year for 216.00 delivered from Simple tire. They are made in India, but for what I do they are fine. I have my own tire changer, so its easy for me to dismount and mount tires.
Old Machinist
May 27, 2024
698
809
NE FL
I put Galaxy Mighty Mow turfs on my John Deere 4310. They worked great and held up fine. The rears still look good but the fronts finally gave up the ghost and started cracking and one bulged out. The fronts were always worrisome when doing loader work so I replaced those with 10 ply R4 loader tires. They were the same diameter so I just left the turfs on the rear.
The Mighty Mow turf is a deep aggressive turf tread and provided excellent traction and a soft ride. I ran 20 lbs in the rear and 25 in the front.
fmgsr
Kubota, LX2620 - Kubota BX2380 (retired)
Dec 19, 2018
91
47
PA
Bought from Kubota dealer, for the BX front, Twice, one each time. First one was $86.00
Second one was $91.00. That was New on Rims. They told me $128. if I want just tires. HAHA
Scm
BX23S
Sep 28, 2024
402
402
Missouri
I was mislead by the pic at simpletire. The tires I was looking at, does not include the rim. Called my dealer (not that one) $199&$209 for rim + tire. Not sure why different prices.
Messicks was about the same $, but I'm sure shipping would of at least doubled it if not 5X more
