Dirty Inlet Z482
Nauty
20
10
Scotland
I bought another Beta 10hp marine boat engine not running.
I connected it all up and sure enough it turns over , white smoke /vapour out the exhaust but not starting so I'm thinking compression must be bad.
I've removed the head and nothing strikingly bad but the inlet ports and valves are really sooted up and oily and I did notice some exhaust puffing out the inlet when I was turning it over and thinking it odd.
I don't think this engine has been stripped before so I imagine the timing is good and no damage to pistons/valves.
Anyone any ideas
To summarise ...Symptoms are
Cranks over nicely but wont start
Sooty/oily inlet manifold /ports and valve stems.
Could really bad injectors do this? Can't test them here unfortunately.
10,690
Valve are not seating.
This could be from the valve lash not being set correctly or bad valves or seats.
I would start with adjusting the valves.
Bad Injectors would not cause this.
Nauty
20
10
Scotland
I'll take a better look at the valves tomorrow but they looked perfect and lash was spot on.
Could it be head gasket? When I took the head off the gasket was in two pieces(layers) but no intermix so probably not that.
10,690
Some off these engines had a head gasket and a metal shim, so be mindfuul of that on replacement.
It wouulod be near to impossible for a headgasket to cause exaust out the intake port of the head.
A cracked head is another thing that could cause that to happen.
Nauty
20
10
Scotland
valves are covered in a sooty crust , looks like they’re not seated as the contact surface is black as well
this is an inlet valve
they’re a mess
10,690
they’re a mess
Yea, that does look like they weren't seating at all.
Also looks like there is a lot of wear on the valve stems?
Workerbee
Zd21
Mar 1, 2020
357
225
MN
Does the engine have a crakcase vent routed into the air intake? That sure looks like coked up oil deposits on your intake valve.
Nauty
20
10
Scotland
I think it does have that but don't think that's the issue.
Trying to work out what's happened to this engine.
It was on a rescue launch on a tiny lake near London. I wonder if it's never worked hard.
Like I said exhaust fumes coming out the inlet when I was cranking it over so it would appear both inlet valves weren't closing properly and it's sooted up.
I'm getting new valves ,guides , seals etc and refit the head and see what happens. The bores look ok.
Nauty
20
10
Scotland
I've had the head rebuilt and new valves ground in.
Still won't start so checked compression , virtually zero. Took the head back off and I remember there being a figure for how far above the block the pistons should go at TDC . (protrusion)
Anyone know what that is? I think it was about 0.5mm
I've looked at these and the piston is about 2mm below the block face at TDC so looks like I have bent conrods from hydrolocking.
