Brake vs Reverse
Chadwiseman
Bx1880
Oct 5, 2024
I've had my BX1880 for about 2 years, and I've tried to minimize the use of the brakes as mush as possible as I understand it is a little work to replace it later down the road. from time to time, I do need to slow quicker or stop. Is there any harm in using the hydrostatic transmission in reverse or forward as a means to stop the motion of the tractor, or should I always use the foot brake? Thanks.
Vlach7
L47 305DT JD500C
Dec 16, 2021
449
322
Frazier Park Ca
I guess it just comes down to what is cheaper to fix, and I can't imagine an HST would be that. o_O
10,685
The HST doesn't care about applying reverse force.
But then again the brakes don't care if they are being used.
It's very rare to see HST damage or Brake damage from normal use.
6,933
The HST is designed for hydraulic control of forward, reverse, and braking.
6,870
I only use the brakes when I have to stop quickly, or to hold position.
That, and to make sure that I didn't set the park brake inadvertently...
I've done that before too.;)
John T
2017 BX23S
May 5, 2017
1,245
777
under a rock
Using my BX to mow every week, I don't think I've ever used the brake.
Bee-Positive
Nov 16, 2022
778
778
Amsterdam, NY
Have had my BX1880 for 4 1/2 years and has just over 400 hours on it. The brake peddle is so high up that it is "unnatural" to always raise my foot to try and stop or slow the tractor. Once you take your foot off the throttle peddle the tractor slows down a lot automatically and if needed I'll nudge the pedal in the opposite direction to stop the tractor. Keep in mind I am not jamming it to stop abruptly.
I do use the brake when needing to maintain position like staying in one spot while dumping a loaded bucket, or backing up to an implement, and I always lock it when getting off the tractor while it's running.
Trustable
l2501HST
Jul 5, 2022
360
373
I frequently rock between forward and reverse at lower speed, especially when doing loader or snow work. I don’t think it would be an issue at all based on my understanding of the hydrostatic system. The only time I use my brakes is when I park it, need to stop on a steep incline, or when I forget to take off my parking brake and wonder why I’m going slower than usual - that happened a lot when I first got the tractor - not proud of it. Pretty much as soon as I let off the treadle the tractor stops within a foot it seems, so I never use it to slow down. That might just because of the R1 tires, maybe turf tires will roll a bit more.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,520
548
All I can say is you will never wear the brakes out. And as far as using the hydrostat as a brake, I'm not gunna say whether it takes life off them or not, but it specifically states in my RTV's owner manual to not use the hydro for downhill and braking purposes and to use the actual brakes.
But I'm guilty. The hydro braking in the RTV is so strong, by the time you let off the throttle and get your foot to the brake pedal it's already stopped, LOL Same with downhills.....if I were to use the service brakes it would just stop.
4,081
2,776
I don't understand the question. With HST I never use the brakes for driving, only for parking on hills or using the PTO when I'm not in the seat.
When I take my foot off HST pedal - the tractor stops. The only time I use the brakes when driving is when I forget to release the parking brake.
If you choose to put your SCUT into reverse while still driving forward it's your machine to use and abuse. IMHO Brakes are cheaper to replace than HST.
JonM
Nov 29, 2024
237
598
wisconsin
i am not sure if the bx hydrostat has a setting you can adjust for how agressively it stops after releasing the pedal or not but my l6060 has such a thing. i would investigate the manual and see if you have that feature. if so just set it a bit more agressive
6,933
I rhink you are talking about the damper on the pedal.
4,062
I made what I consider a terrible error…. immediately after changing the 11 gals of expensive SUDT2…. I mowed for a half-mile with the parking brake SET. (Since I was mowing in 2nd gear pulling the mower using 2450 RPM to run the PTO, …the tractor gave no indication the brakes were Firmly-SET).
I”ve added an elect-switch activated by the park-brake-lever and a “Son-A-Lert” which loudly BEEPS intermittently and AGGRAVATINGLY when the park-brake is set…..and I”ve not had that problem since.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,190
2,846
Near Lancaster, PA, USA
It may be like my L4240 with the HST+. There is a dial on the dash for adjusting the response time. At one end it's like slamming the brakes. At the other end it'll let the tractor coast for quite a while.
10,685
yea no, the BX has no adjustment in the HST pedal responce.
Bee-Positive
Nov 16, 2022
778
778
Amsterdam, NY
Just came in from removing the snow drifts from the driveway AGAIN!!! I know seat time is always good but it's starting to put the FU in FUN.
Cursing down an inclined driveway, take my foot off the pedal, BX come to a stop in about 5 seconds as if you put the brakes on. Same going backwards.
Bee-Positive
Nov 16, 2022
778
778
Amsterdam, NY
Always with the cursing...
Well that's 2 for2.
I think my spell check has a mild case of the Coprolalia virus.
Cruising, cruising, cruising, cruising...cruising. There, now I shouldn't need spell check.
Now why did I go into the kitchen again...??? 🤔
