BEE KEEPING
2,902
I thought maybe the experts on here might give me a bit of advice. I have a large locust tree that is failing and will need to come down this year or next. A large hole at the bottom has a large number of bees going in and out undoubtedly producing honey. I would like to save the bees, the honey and the firewood but those tasks are above my skill set. Should I contact an expert and who would that be?
See this link for some information
When this happened to me in a tree in the backyard that I did Not want to remove it was handled differently each time (3 times).
1st and 2nd time were when Africanized bees were prevalent in Texas. The first time the bees were exterminated by a professional person since no one wanted to catch them. They basically just examined the tree to see where the bees were coming and going from. They then sprayed those areas with soapy water to remove bees and then sealed the holes with expanding foam. They then sealed any suspicious spots in the tree. The second time I did the same thing since it seemed fairly safe and easy. The soap was Dawn dish soap with water in a pump up sprayer, that makes them too heavy to fly and may suffocate them.
The third time (less concern about the Africanized bees) a bee keeper came out with a hive that had a few bees and a queen bee (probably purchased a queen). They put an excluder on the tree over the hole(s) the bees had found. That is simply a cone made of screen wire with the end sized so the bees get out but they can’t squeeze in. They routed that in the hive that also had another place on the other side to get out and back in. Since they could not get back to their own queen and the new queen needed workers, they just stayed with the new hive. After a couple of weeks they then sealed off the tree and left whatever bees were in the tree. They may have left the hive another week and then sealed it at night and took them away.
And yes, I had tried to keep the tree sealed up every year but that seemed to be impossible. It had been damaged by fire and took about 30 years to seal the bark back over the damaged area.
lynnmor
B2601-1
May 3, 2021
1,763
1,570
Red Lion
Thanks for the reply. Even if I get the bees to vacate, there may be a mess if I chainsaw into the honey. I may invest in a hive and then start picking away at the tree. It might require cables to guide the fall, there is no telling how much rot and bee damage is inside. Falling the wrong way will damage my shop. I need to drop it into the neighbors field and that will have to wait till the crops are off but that gives me time to move the bees to a new home.
ACDII
Oct 21, 2021
690
432
Illinois
I have 4 acres of hay with a lot of clover along with a few hundred Lavender plants, and going to add a few stretches of wild flowers. I think it would make for some good bee activity. I do see them around the lavender. I also have a nice shaded corner out of the way to put hives. Its the keeping part that I have no clue about. LOL Bet it would make some nice honey.
GrumpyFarmer
4,999
IMO, it is not an inexpensive hobby to start.
As far as keeping them, I think I am still a behaver (3 years in), but aggressively aspiring to be a bee keeper.
before getting to happy with the throttle, I’d recommend one of two things (or maybe ideally both):
1. Find a local club or university that has a Bee Keeping class…if they have classroom and lab activity that would be ideal, depending on time of year and weather maybe not possible.
2. Find a mentor that is interested to help you with problems solving and reference point to diagnosis as to what is going on in your bee yard.
3. If you don’t have 1 and or 2, it’s going to potentially challenge you. (If you do one of the above, you will find the other)😉
4. If you have the time join a club, but id start with the 1 and 2 above before ordering or buying anything. After a class, if still interested, then buy the appropriate gear and go visit some other people’s bees. (At this point a decent class should be +/- 200ish dollars and you should get some reference material including books, periodicals, etc. the suit maybe getting close to the same. You’ll BEE into it for close to 500 before you have a hive or a drop of honey. If starting from scratch I think it would be very reasonable that the first drop of honey costs $1k, not out of question to cost much more actually. That’s the reality. It’s not cheap to get started from scratch.
that BEEing said it can be enjoyable and rewarding IMO if you enjoying problem solving, care taking of livestock, and learning / developing knowledge of the natural local environment thru the 4 seasons.
Hugo Habicht
G1900
Jun 24, 2024
1,505
2,159
Ireland
Go for it. Lavender honey is delicious! :love:
Bee-Positive
Nov 16, 2022
778
778
Amsterdam, NY
The largest US honeybee die-off on record, with beekeepers losing on average 60% of their colonies, at a cost of $600m
Scientists have been scrambling to discover what happened; now the culprits are emerging. A research paper published by the US Department of Agriculture (USDA), though not yet peer-reviewed, has found nearly all colonies had contracted a bee virus spread by parasitic mites that appear to have developed resistance to the main chemicals used to control them.
2025.05.28.656706v1.full.pdf
US honeybee deaths hit record high as scientists scramble to find main cause | US news | The Guardian
GrumpyFarmer
4,999
Good day.
Today I set up a manifold (so to speak) and this will be my first attempt at a harvest in 3 years. So I plan to give it some time and check later today and see how we did. 🐝 🍯
Shawn T. W
Dec 9, 2024
698
1,292
SW Missouri Ozarks
Yeah, once they cap the cells there is no flow ...
I kept up to 7 hives when I lived in VT, sold them when I moved to a town house on a golf course in Arizona ... Thought about a couple of hives now that I have property in Missouri, just East of Springfield ... But I don't really use that much, less then 10 pounds a year, and when I saw the cost of hives and packaged bees, I decided to let the local bees do what the do, I do have a few fruit trees, but neighbors get there's pollinated from wild bees ...
I'm also quite reactive to stings, or any insects ... Not life threatening, but I'll get a huge welt over 4" diameter, once stung in forearm by yellow jacket entire arm swelled ... All started when as a teenager worked at golf course cutting grass, ran over three different yellow jacket nests in the ground with a push mower ... 138 stings!
GrumpyFarmer
4,999
It’s a bit of a long story…
my spousal unit decided to buy the most expensive hives she could find…they are called flow hives. I think the goal has been to make the most expensive jar of honey 😉.
sort of serious but I do believe if there was an Olympic event for most expensive jar of honey we would most certainly be on the podium. 😂
anyway she is allergic to bee stings…no kidding…I was completely against it and sort of drug my feet and said if she doesn’t go thru immunotherapy and doctor says it is safe we are not doing this. Well she called my bluff went thru 3 years therapy (total of 6 now…doctor seem to like our insurance plan) and was given the green light 3 yrs ago to have bees. So the therapy is working…so that is a positive. She still has to carry EpiPen.
so the flow hives is a Langstroth hive with a special super that lets you drain the honey out…it’s pretty neat actually and much less invasive on the harvesting side. Other than the super everything and all the work inside the hive is the same. So that is the type of hives we have. The deeps and all are interchangeable with langstroth and care taking is the same.
on the harvesting side, when you open the frames, the honey drains out the bottom and yields raw unfiltered (is pure clean honey no debris in it) out the bottom. You could literally fill the jar right from the tap on the hive if you wanted.
what I did was put food grade pvc tubing on the spigot and ran that into the bucket. So what you see there is 7 frames of honey draining into that bucket.
when it’s done draining I will carry that bucket in and then we can bottle to our hearts content. (I put a honey gate on the bucket so we can take the whole super worth of honey in and keep in the bucket and fill jars as needed.
not sure that makes sense or not. Basically it’s a langstroth with an expensive super that allows you to collect raw unfiltered honey straight from the hive. (There is no hot knife or extraction
since the special supers did not cost enough, To make it more expensive we bought the most expensive low voc paint my spousal unit could find in variety of different colors so we would be sure not to use it all….that’s what I think ultimately will put us on the podium. 😉
short answer is this steals from the bees in a less invasive harvest. Sort of like when our federal govt takes money from pay check without asking first.
Bee-Positive
Nov 16, 2022
778
778
Amsterdam, NY
I looked into Flow-Hives a few years back, never pulled the trigger though. I like the manifold you set up, prevents open dripping which tends to attract bees looking for a "free" meal even if it is their own honey.
GrumpyFarmer
4,999
Thanks. They have gotten a bit of bad press IMO, but I have not been at this hobby so long to be stubborn just yet. The tubes and bucket worked out really well.
I Just now I came in from collecting the first harvest. When I pulled the taps/hoses off the hive, the bees seemed to think I was out of place…but everyone played nice. I brought the bucket back to the house and a couple bees wanted in when I pulled the tubes and lid off. One bee managed to get in along with a 2 knats…I picked the bee out by its wing and ate the knats with the honey on my finger that I fished it out with🙄.
The good news is:
1. My wife was easily able to stand there while I closed up the bucket without her gear on. (Not really sure how spousal unit could handle harvesting a super without full suit on…so for her it may very well be worth the price)
2. I installed the honey gate correctly and no leakage yet 🤞.
3. I did not mis install the tubes and flood the hive.
4. Knats never tasted so good.
I am not sure how many of these hives we will get…we are pretty remote and pretty private (not in a regular club), and we don’t have a centrifuge and honestly weren’t sure we would like bees so we thought the Flows would be a good start before going all in. We are up to three hives and have one in a box (we been buying them off eBay when we see a fire sale price on new/open boxes unused and actual Flow hive brand…there are some really good deals we have found which takes the sting out of the initial price. We have capped our limit at 4 until we move north. When we do that I think we will have to decide we want more hives or not and in that case we need to go to regular hives if we are capping up, and get a centrifuge…or we’ll stay with four and bee happy with what we move up there I think somewhere between 3 and 5 and the math starts to suggest the supers are so expensive may be better to get some equipment for harvest vs a Flow hive, unless you really don’t want the hassle and extra equipment. 🍯
GrumpyFarmer
4,999
We are starting to get frost couple time a a week now…it’s about time to button the ladies up for the year.
Tonight we make candy. (We’ll set this in the greenhouse and let it bake now)
NEXT warm day we install the candy and put the blanket on the hive.
Bee-Positive
Nov 16, 2022
778
778
Amsterdam, NY
Interesting tidbit popped up yesterday.
Mad Honey
Turkey’s Black Sea region is one of only two places in the world to produce it, the other being Nepal’s Hindu Kush Himalayan mountain range.
The purple rhododendron blooms in spring. The bees collect nectar from those flowers, and that’s how we get the mad honey.
The nectar contains a naturally occurring toxin called grayanotoxin. A spoonful can pack enough buzz to deliver a gently soporific high — while a jar would land you in a hospital.
There’s no hallucination involved. It just causes dizziness, low blood pressure, a slight fever, nausea, and difficulty walking.
In the 4th century BCE, the Greek military leader Xenophon wrote of soldiers traveling near Trabzon on the Black Sea coast who overindulged on the sweet treat: “Not one of them could stand up, but those who had eaten a little were like people exceedingly drunk, while those who had eaten a great deal seemed like crazy, or even, in some cases, dying men. So they lay there in great numbers as though the army had suffered a defeat, and great despondency prevailed.”
GrumpyFarmer
4,999
Good day.
View attachment 158507 View attachment 158508
Happy New Year!
just an update from last years (our first)…today we finally got around to filling a few bottles! (This is all raw unfiltered honey straight from tap…no extraction/centrifudge)
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,143
1,717
Pittsburgh
I eagerly await spring so I can start enjoying fraesh wasp honey.
GrumpyFarmer
4,999
We finally broke freezing today…47 and the girls starting carrying out the dead bodies. As morbid as it looks as it is a sign of life. IMO they broke cluster and probably took some cleansing flights.
I’ll crack it open next week if we break 50 and check on their stores.
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
433
691
NH
The shaking bit I never mastered either, too many bees started to fly then, possibly including the queen, she must be sitting near the branch (I think). Thats why I use garden secateurs. Cut off the branch outside the swarm first, then put the box around the swarm and cut if off the branch.
One option: drop the swarm onto a sheet. If possible and seen, place queen in hive or her own introduction cage, If not seen, then "bag" them up and shake them out into the deep. Spray box before hand with sugar water to entice them to stay while gently inserting frames. Lots of variations on swarm catching theme. Just be cautious with ladders or climbing.
Gaspasser
Dec 16, 2023
433
691
NH
Hey grumpy. Look for yellow-brown spots in the snow. Signs of them defecating during cleansing flights.
