Changing hydraulic fluid, how do you exchange the loader lines
bobaloo22
B7800 hydrostatic
Jan 30, 2026
11
Central Virginia
I’m about to change the hydraulic fluid in my B7500 back to Super UDT2. How do I get the old fluid out of the loader lines?
Thanks,
Bob
7,243
Thanks,
Bob
Assuming the old fluid is not contaminated just drain and refill the sump. The old fluid in the loader is not a concern.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,186
1,794
Pittsburgh
"The solution to pollution is dilution."
Reactions: 6 users
SDT
Apr 15, 2018
3,682
1,407
Thanks,
Bob
Not possible without a lot of work which no one does and very few worry about.
JonM
Nov 29, 2024
277
662
wisconsin
with the cylinders retracted disconnect each hose on each end and drain. its a pain in the ass. if you are insisting on it you pretty much gotta disassemble the cab/seat area to get to each hose where it connects to the pump....
you can get super crazy with it if you want to.
11,757
Thanks,
Bob
Out of interest, you say "back to Super UDT2" ... so what is currently in the tractor?
Whenever I buy a used implement with hydraulic cylinders, I always drain out the oil before I connect it to my tractors. It's really not hard to drain the oil from your loader if you really wanted to, but others have already indicated that they don't think it's necessary or worth it, but it doesn't really matter what they think if it's worth it you. Sometimes the peace of mind that comes from believing in something that isn't real or true is worth it. Take all religions for example. 😂
Sammy3700
Feb 20, 2012
463
Red Springs, NC
You can remove a pin at one end of each cylinder and remove both lines and blow easy with air on one line at a time which will cycle the cylinder each way this will remove all oil. Once you put it back together just remember to cycle each function to refill the system with new oil
4,199
Anyone who worries about hyd-fluid remaining in implement or loader lines…. should think Twice before attaching their brand-new equipment to their tractors…. (or any rental implements.)
and while they’re worrying….. how they gonna get the air out of the cylinders after they blow ‘em out…?? 🤣
(go back to worrying about the extra money wasted you paid for when you installed that Shell Oil in the engine….. when you discover that cheaper SuperTech is the identical stuff made by SOSUS (Shell Oil).
bobaloo22
B7800 hydrostatic
Jan 30, 2026
11
Central Virginia
It has Supertech in it now and it’s viscosity is way too thick for single and below zero weather. It’s got 200 hours on it but now that the UDT2 is available I’m changing it. I was just curious if anyone had run into an issue with this. I just really wanted to see what type of response I would get as this is my first post.
7,243
You can minimize the amount of residual oil left in the system by lowering the 3pt and fully retracting all cylinders.
SDT
Apr 15, 2018
3,682
1,407
" Whenever I buy a used implement with hydraulic cylinders, I always drain out the oil before I connect it to my tractors. "
So do (did) I. One has no idea what has been used in used equipment or how dirty it might be.
