LA211 Loader Bucket
bbraniger52
BX2200
May 19, 2020
Kimbolton, Ohio USA
The cutting edge on the my LA211 loader bucket is worn unevenly.
It is welded into the bucket.
My dealer told me the bucket was too hard to drill and add on a replacement cutting edge.
Any solutions for a new cutting edge!
Thanks!
Bee-Positive
Nov 16, 2022
645
675
Amsterdam, NY
The bucket is not too hard to drill with a step drill bit and 1/2" drill. I did mine to mount a 2" receiver. Maybe the cutting edge itself is to hard but the bucket is not. If you find a wide enough replacement edge you could drill it and bolt one on. BXpanded also makes a straight edge you can bolt on. I have their toothed cutting edge for digging, wouldn't dig half the stuff I do without it. You'd have to measure your bucket and contact them to make sure one would fit.
10,397
Thanks!
Weld a new edge on it.
6,689
Any decent welding shop can replace the cutting edge on your bucket. They will cut the old edge off and weld a new one on. Its a very common repair.
dlsmith
BX2230, LA211
Nov 15, 2018
1,331
979
Goshen, IN
I had a new cutting edge welded onto my bucket, then bought a replaceable cutting edge for a BX, drilled holes in the welded cutting edge and bolted the replaceable blade onto it.
#BX2414 48" Bolt on Cutting Edge for BX2448 Bucket
IMG_20191228_153728294 (Custom).jpg IMG_20191228_153739909 (Custom).jpg IMG_20191228_153908973 (Custom).jpg IMG_20200123_111245514_HDR (Custom).jpg IMG_20200123_111309508 (Custom).jpg
