Durn Fern, TLDR
3,970
2,463
I know a lot of you don't want to read all this, so I'm starting a separate thread to continue a post in a different thread.
Background: winter storm Fern hit north Ms and mid Tn, beginning Sat, Jan 24. A band of ice from freezing rain caused lots of power outage starting late Sat night/early Sun morning, cascading into some loss of water supply.
Thur 2/5 (day 12) Drove from Jackson, Tn to Oxford, Ms via Tn18/Ms7, ~100 mi. I started seeing damage just north of the state line, worsening southward. South of Holly Springs, traffic was stopped about 15 minutes for crew working on a line crossing the highway. Then there several crews working along the road and a steady stream of grapple trucks pulling trailers, turning into a vacant field next to a Dollar General (of course).
When i got to my place, the first problem is Katy Kubota is boxed in. My primary drive is the powerline ROW and trees have the line down. The temptation is strong to clear that, the line is obviously dead, the wire's on the ground. But 7200 v, wrath of poco, common sense prevail so I'll clear an alternate trail.
Here's what I had
After an hour or so with the chainsaw, I had a path pushed through to get Katy out. My sister had a fair size cedar and another tree across their primary drive, so I started cutting the cedar. I thought they were thawed out, but as I cut I finally figured that the ice that brought the cedar down was now a low mound of ice, glueing the tree top to the ground. It's supposed to be warmer the rest of the week, so it should thaw out.
My sister has been hauling towels and blankets from the pound to our two dryers. Animal control is still running on generator; they can wash but don't have enough power to run dryers so they called for volunteers.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
Don't even think about going near a power line on the ground. You have to assume it is live.
On the positive side: if you decide to go near it and it is live, it will be quick and you will never know what hit you.
And if it ever happens that a high voltage line (say, greater 20kV) falls down near you, do not walk or run away from it, keep your feet together and do jumps. The voltage potential between your feet can kill you otherwise.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,227
1,850
Pittsburgh
You could do the "electric slide".
boogie woogie woogie
Bee-Positive
Nov 16, 2022
1,199
1,104
Amsterdam, NY
Wow that's a lot of damage. We only got 16" of fluffy stuff up here.
7,356
Ton of damage - - hope you can get through it.
We're forecasted for high of 2F tomorrow with winds up to 40mph.
Just hope we don't lose power also.... 🥶 :oops:
3,970
2,463
Fri 2/6
Tried to help old lady across the road get her service mast which was bent horizontal, so when the powerline is fixed she'll be ready. 'No good deed goes unpunished' fits here. Bottom line, it's done, cost her $425, 'nuff said. Sister and I took her to Wendy's (her choice) for lunch. I think she enjoyed being out with somebody besides family.
Spent the afternoon clearing the trees off sister's driveway. It was a beautiful sunny day, high mid 60's.
PoCo down to 4200
3,970
2,463
Sat 2/7
Got a late start, debris truck blocked the road a little while. I had planned a trip to HD and Wally for spare chains and replacement groceries. Couldn't find my jacket, did I leave it at Wendy's? Sis asked if she could ride, she had towels to swap at the animal shelter. So that was most of the morning.
Sis, BIL, Katy and I spent the afternoon clearing out the driveway plus the adjacent jungle. I'm sure glad now I sprung for the SGC1060 grapple; it's paid for itself. We had a little help from the debris guys and had a productive afternoon until Katy stubbed her toe. I didn't have enough pressure in the right front and pushed the bead loose. BIL and I worked on it to no avail, plus the stem is leaking. So now I need a tire repair, hopefully before Monday.
It was another nice day, high 52F. Poco at 3400. Somebody cut one of their fiber feeders, putting an area out.
3,970
2,463
Sun 2/8
There's a tire shop in town that opens at 10 am on Sunday. They broke down the tire and discovered it had a tube. So I went tube shopping. Found a 15" tube, but it had a long stem which I figured I'd rip off in short order. So I bought a tube repair kit and enlisted my sister's aid to patch the tube and try to put the tire back on. That proved futile, so we spent what was left of the day cutting broken trees and limbs and stacking them. In the process, I found Katy is wearing 27X8.50-15's instead of 10.50's. Monday morning I'll see if my Kubota dealer has 10.5's and get the old tire back on for a spare. Oh, BIL & I got called to the neighbor's for a generator outage. The GFCI's had tripped, didn't even know they had GFCI's.
Another beautiful day, 60's. Supposed to hit 70 tomorrow. Poco is down to ~2700. I have a feeling my neighbors and my shed will be about the last restored.
3,970
2,463
Mon 2/9
After stops at dealer, tire shop #2 and tire shop #3 I have a serviceable tire and two new ones on the way. And it only took half the morning. Sis and I spent the rest of the day clearing and stacking behind the poco crew. And some at the neighbor's to clear a tree off her fence. Oh yeah, my neighbors and my shop got power today! (After I remembered to reset the main breaker.) My fiber was still working, but the house at the end of the line isn't.
Beautiful day to work outside, but it didn't quite hit 70. Poco is down to around 2,000.
3,970
2,463
Tue 2/10
Picked up the new front tires and put them on. Replaced a couple of saw chains and got to work. Since the power crew did their thing, I was able to get my primary drive to the shed cleared. The power line corners at my shed and I started clearing down the other span. Until I noticed how low the lines sag at mid-span, then I abandoned that and started clearing around the shed. There's probably enough stacked at the road to fill one of these (not my picture).
These trucks are everywhere, you can hardly go anywhere without encountering one.
It's supposed to rain tonight and I have to go home anyway, so that's all I'll get done this trip. Electrical outages are down to around 1400.
3,155
Those trucks remind me of Soylent Green!
They are from FEMA and will be around for a while. We had bad floods in July and still see them here in central Texas doing their cleanup thing. I don’t know if they have just a few that travel around or if they have thousands scattered across the country.
3,970
2,463
I talked to one of the guys while his partner was grappling. They're out of NW Arkansas; he said they've been coast to coast plus PR?, I think. Wish I'd asked him how they got their equipment across the water. He said when he's home, he has a tree trimming/firewood business.
I think we've filled a couple of those. Plus what the county pushed to the side of our little county road. Their was a similar storm in '94. They burned the debris then, but this time they're chipping. Mulch is going to be cheap around there this year. Firewood will be plentiful.
