B7100 hst 4x4 box blade size?
Morgan44
38
Walton KY USA
Just a as the title says. I'm looking to make this one of my next attachments. Question is 4' or 5' ? Will the 5' be to much to handle? Anyone with experience with this scenario?
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I have a B6100 2wd and I pull a 4ft box, sometimes depending on terrian I struggle a bit if its on a hillside. Other times I'm mostly on level ground and pull the 4ft box just fine and feel like I can pull a bit more. Sometimes I struggle every now and then breaking up hard ground with the teeth down also.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
MHO get a good quality heavy built box scrape that will work properly and 4' is all your tractor will handle.
I have a L3000 which is double the hp of a 7100 and a 5 1/2' box is all I can handle when I'm really making it bite in and move material.
hodge
Nov 19, 2010
2,954
517
Love, VA
I agree- 4'. 5 may work, but you will undoubtably not be able to use it to its fullest potential. What's an extra foot, if you can't make use of it?
3,162
I have a B7100 with the originally issued 42" Gannon box blade, and based on it's performance, I would not go over 48". Get the heaviest, stoutest box blade you can afford, weight & strength really make a difference here.
3,162
Probably depends on your soil & planned uses. Out here the ground is so hard, compacted, & rocky I'm sure I would have trouble with a larger box blade.
But if your soil is soft, sandy, or free from rocks you can probably get away with something larger than 4 ft..... if you are only going to re-grade an existing gravel drive, or drag loose material to level low spots...... see what I mean?
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
You might get by dragging a wider box but you will never get the full potential out of it.
Myself I would rather have a 4' that worked as intended than a larger one that I got 50% use because the tractor can't pull it. In the end it's all up to you. I have a strong feeling that your 7100 will handle the 54" box fairly well almost every time you use it. When you really get to digging or have a full load of material there will be times it can't handle the load but for the most part you'll be fine. JMHO
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Like I was saying in my post, sometimes I feel like 4 foot is little and I can pull a bigger box and other times I struggle and fit with it depending on the job. I look at it like this, anything I can do with a 4ft box sure beats the hell out of a shovel and a rake and is faster then I can anything I do by hand.
Morgan44
38
Walton KY USA
Is that a 4' box? What brand is that? I have turf tires so I think my tires are a little wider than yours, but that looks great. That's just my style, nice and clean.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
With turfs you sure ain't pull'n no 5' box anyway.
The box is a store brand of a local dealer.........don't know the name.
