B7500 wheel weights
TimU
Kubota B7500
Jan 28, 2026
MO
Has anyone installed rear wheel weights on a Kubota B7500? What works? The best option I’ve found locally (to avoid shipping) that I believe will work are the BM17965 from John Deere. I would obviously need to paint them orange. 😄 Has anyone tried these? Thanks
10,986
Have you filled the tires with ballast?
SDT
Apr 15, 2018
3,678
1,403
No, and don't believe anyone makes rear wheel weights for your 7500.
Liquid ballast is almost certainly your best option.
SDT
Apr 15, 2018
3,678
1,403
I had fluid ballast in them before but didn’t replace it when I replaced the tires. I would prefer bolt-on weights in case I get a flat.
Agreed.
I changed all of my own tires and almost never used liquid ballast but, aside from a three point mounted counterweight, you have few options other than cobbling something up.
TimU
Kubota B7500
Jan 28, 2026
MO
Agreed.
I’m ok with cobbling as long as I can paint it orange and it works 😄
Ping
BX2370-1
Dec 25, 2018
362
378
Troy, Ohio
TimU,
If you have access to material and a lathe, why not roll your own? These are on my BX for comparison.
If diameter is prohibitive, you could also burn out rounds and laminate together to whatever thickness (weight) you desire. That option would make install/removal job easier as you wouldn't be handling as much weight all at once. weight.jpg
TimU
Kubota B7500
Jan 28, 2026
MO
TimU,
If diameter is prohibitive, you could also burn out rounds and laminate together to whatever thickness (weight) you desire. That option would make install/removal job easier as you wouldn't be handling as much weight all at once. View attachment 169421
Ping, I don’t have access to a lathe. I’m just looking for a reasonable commercial option.
Hugo Habicht
G1900
Jun 24, 2024
1,541
2,234
Ireland
You can buy discs laser cut to size. All you have to do then is drill a few holes and bolt everything together. And I like @Ping s idea of handling smaller weights.
Bee-Positive
Nov 16, 2022
985
939
Amsterdam, NY
I used a set from an old Craftsman lawn tractor my BX replaced, fit perfectly. Measure your rims, there may be options out there.
Russell King seems to have a good idea there depending on price.
Chains & Weights - Rear.jpg Good luck!!!
FTG-05
Jul 21, 2013
346
190
TN
Make your own. ~250 lbs each, made from Gr8 bolts, steel rebar, lead and concrete.
FTG-05
Jul 21, 2013
346
190
TN
I've had my L4330 since 2013 with 513 hours on it. It's now got just over 1500 hours and it's been +13 years. I replaced the water in the rear tires with a mixture of RV antifreeze and water within the first year I owned it.
The number of flats I've had: 0
The number of times I've worried about flats: 0
Worrying about flats vs. worrying about the real danger of overturning your tractor - and getting seriously injured or killed - isn't even in the same zip code much less the same time zone.
First step is to fill your rear tires, then worry about wheel weights.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
The solution for my B7500 back in '02 was to fill the rears with washer fluid and eat bigger meals.
