Diesel Additives - Time to Change Brands?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,199
3,511
Opti- Lube for all my diesels. I don’t bother with their “Ag” formula. Just the red flavor.
10,795
I decided to try XPD Opti-Lube last spring because it had the best lubricity (wear scar reduction) of the products tested, and it increased cetane rating. I don't care about the potassium content since head gasket failures are not a concern for me, and it was only the presence of potassium in the engine oil (from the fuel addidtive) that TOG objected to.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,199
3,511
Potassium in itself is not a problem. Only that it can hide a coolant contamination in an oil analysis. If you know the level is elevated due to the Opti-Lube, then you know what your “normal” level is.
You may already know all that, but others might not 😁
Lug66
LX2610HSDC, Z422KWT
Jun 7, 2023
118
67
SW Michigan
I’ve used Opti-Lube XPD, Boost and Winter in my Kubota tractors and ’14 6.7 Powerstroke since 2014. No problems in 12 years of usage.
