Leaf in the fuel tank!
Hugo Habicht
G1900
Jun 24, 2024
1,541
2,234
Ireland
Greetings all .. New to the forum. I do cemetery restorations and use a Kubota BX23S in my work. Recently, I was refueling, and an oak leaf came out of nowhere and landed directly in the tank and disappeared out of sight. I don't know how to retrieve it. Any ideas?
One thing came to my mind, nothing to solve your problem really (or maybe it would). How probable is this event, a leaf flying through the air and falling into the tiny tank opening while the cap was off? Have you considered buying a lottery ticket this week? :giggle:
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
The biggest issue with the BX tanks is the design of the tank makes it really hard to get anything into the opposite end of the tank.
If that's the case one can empty most of the fuel and drive across a slope (hill) where the remaining fuel sloshes debris toward the filler side.
In the shop: Lay a 4x4 on the left side of the tractor in front of the rear wheel. Put a 2x4 across it forming a cross and drive the tractor on the 2x4, leave the FEL off the ground. Step on the long side of the 2x4 using it as a leaver arm to raise & lower the tractor, sloshing the tank. To keep the left side of the tractor elevated wedge a short 4x4 under the wheel with a broom while stepping on the 2x4 and lifting the tractor.
Personally, I don't want to pull a tractor's gas tank, I got other things to do. ;)
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
6,284
2 guys can get the tank out in less than 2 hours, using normal tools in a well lit ,warm garage
vs
a section of stem breaks off, you don't see it and 2-3 months later it semi floats into the spigot and engine stops.
WI_Hedgehog
Apr 24, 2024
1,129
1,646
vs
Then it's TIME for an MX. :ROFLMAO:
Or an M-Series.
7,625
I had fuel flow problems with a 40 Hp gas engine a couple of years ago. I could get a vacuum hose into the tank inlet, but not a very big one. I took an old house vacuum hose and adapted to fit the vacuum. I had drained the fuel and blew it out for an extended period of time, and had the vacuum several feet away. Hoping I wouldn't blow myself up! I retrieved a lot of crap out of there. This is a Dream Whip container. There was a 16p nail, and a good size bolt with a spring in there also .
Maybe you can drain the tank of fuel and try fabricating a hose which is flexible to reach around.
K9Ace
KubotaT2380, Kubota BX23S
Feb 1, 2026
Thank you, everybody, for your thoughts and comments. I ended up pulling the tank, but it wasn't a terrible job. Only said a few curse words.:).
6,284
BTDT....I KNOW the seat assy is (*^&(*(( heavy for a 58 year old to remove by myself !
Glad you did pull the tank. Be sure to get a Mason jar coffee filter for the neck of the fuel tank.
K9Ace
Feb 1, 2026
I ordered one from Amazon. Thanks for the recommendation. I don't want to go through that routine again!
Bearcatrp
Mar 28, 2023
1,367
992
Minnesota
After seeing that in your tank, had to get one myself.
11,758
You saw the leaf .... I'm still waiting for a photo of the thing that started all of this! 😂
I had a BX for five years and the only thing that ever went in the tank was diesel.
Bearcatrp
Mar 28, 2023
1,367
992
Minnesota
After seeing what was in his tank, no way was I going to go through that crap. Cheap insurance.
Bearcatrp
Mar 28, 2023
1,367
992
Minnesota
Are the tank openings all the same? I think a filter there is a great idea, will definitely get one myself.
I would suggest measuring your to insure you buy the right size. Just added fuel today, knowing I dont have to worry about anything contaminating my tank.
