LA301 control valve
JesseStLaurent
B1700, JD 455
Nov 29, 2023
Massachusetts
I have a B1700 with an LA301 loader. Unfortunately, the float no longer works on the loader. I am seeking some guidance on repairing it.
Last time the tractor was at the dealer, I asked them to repair the float and they said parts are no longer available. I ordered a float kit from Messick’s for the LA301, but the components are too large. My tractor uses smaller diameter parts. I have not been able to identify the control valve on my tractor to search for alternate float repair components.
I would be happy to learn there is a way to purchase components to repair the float, but I have also started researching a replacement control valve. Based on my limited knowledge from researching online, this Summit valve (P40G-2K16A1-J) is a reasonable replacement. I am looking for a non-OEM option because the OEM valve retails for around $1800 (yikes!).
Any advice you have on repairing or replacing would be appreciated.
Thank you,
jesse
JesseStLaurent
B1700, JD 455
Nov 29, 2023
Massachusetts
That was my initial reaction as well. I purchased that exact kit, but those components do not fit my control valve. The diameter of the parts is too large. My best guess is someone changed out the control valve before I owned it. I am the second owner.
Jesse
10,443
Jesse
In that case then your best bet is to get a summit valve.
JesseStLaurent
B1700, JD 455
Nov 29, 2023
Massachusetts
It is a challenge to get clear pictures of it, but here are a couple of the valve and then one comparing the rebuild kit I ordered.
Did I select the correct Summit valve? P40G-2K16A1-J Based on following the hoses in my setup, I believe I also need to purchase the power beyond adapter to connect the line that runs to my 3 point hitch.
Thank you for your guidance.
6,717
View attachment 169280 View attachment 169278 View attachment 169279
That looks very much like a Kubota valve. Are there four positions on both spools?
BOOM - UP, DOWN, FLOAT
BUCKET - LEFT, RIGHT. RIGHTER
10,443
Yea that's not the right valve for the LA301
It might be a Kubota valve but it's not a stock valve.
JesseStLaurent
B1700, JD 455
Nov 29, 2023
Massachusetts
I have never noticed a 4th position on the bucket spool, but I can give it a test and report back. I have cab in that direction, so I may never have pushed all the way to ”righter” :)
jesse
6,717
jesse
When you say float does not work how exactly does it not work? E.G. - wont go into the float position, wont hold, or something else? Am I correct in assuming you have had the positioner apart already?
