Engine Heaters to assist cold weather starting. Which type?
Gus1957
M6800, L2501 TLB, BX2370
Dec 17, 2023
90
76
Cobleskill NY
Opinions on the best type of heater assist in cold temperature starting for a quick install.
Magnetic or Oil Dip Stick for a new tractor?
4,238
Wanna boil the oil in the immediate vicinity of the dipstick…? …or the oil in the sump …but leave that iron engine block still cold…?
Get a block heater and keep the entire engine warmed.
SDT
Apr 15, 2018
3,695
1,418
Bingo.
OEM block heater is far and away the best. Second best probably coolant heater, remote type best but radiator hose type acceptable depending upon application.
Gus1957
Dec 17, 2023
90
76
Cobleskill NY
I've had a block heater in my M6800 since new 21 years ago and still works.
My neighbor bought a new 30hp Kubota in the summer and nobody mentioned a heater to him. 1st time in years it's been down to -10F/ -35F with wind chill. We even got 18" of lite snow at 10F that was unusual a week ago.
He needs a heater he can use quickly.
Last time I used a dip stick heater was my wife's 1980 Diesel Rabbit that sat outside. Back then VW recommended putting up to 20% gasoline in the car diesel fuel tank. It worked and got 53 mpg.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,978
2,357
Western MT
If it's in a building or they can put a wind block around it, try a buddy heater or similar near it. They don't have an open flame and can warm a small area pretty well. I've used one in a pinch in my unheated shed to get some work done.
Of course, he should order the proper block heater, but also, it may be there and is just missing the cord. I know Ford Trucks came that way from the factory years ago. In other words, block heater was in the block, but the cable was not there.
SDT
Apr 15, 2018
3,695
1,418
If I needed a quick Rube Goldberg engine heater, I would use a magnetic oil pan heater until I could find a better solution. About as simple as possible.
6,322
IR chicken heater is pretty simple !
FYI just because the engine is kinda warm doesn't mean the tractor is 'ready to go' ! You've got very,very cold hydraulic oil, diff oil, axle oil and some very,very cold steel parts, here ,there, everywhere.Also 1 or more 'computers',alternator and other electronics.
Bee-Positive
Nov 16, 2022
1,159
1,072
Amsterdam, NY
All my "Spiddy Senses" are going off!!! Danger Will Robinson!!!
I personally would not mix gas and diesel in my tractor even if others say it's OK.
7,681
That was the method then to get the engine going in extreme cold weather. I think it was 10% maximum though.
4,238
That’s the standard for Cummins in a Ram pickup. Every Cummins has a block-heater installed…. leaving it up to the owner to add the cord to plug it in or not. (Mine is…. plugged in tonite…have no plans to drive it for a few days..but if I need to…it’ll crank instantly and be already warmed to hit the road.)
Trash Panda
L2501
Feb 18, 2022
287
270
Wyoming
If it won’t start with the factory block heater running, then it’s too cold to use the tractor anyways.
Go back inside and stoke the fire.
Donystoy
Dec 10, 2013
737
379
Binbrook, Ontario
Block heater is the way to go. Many years ago on the farm we would cover the entire engine area with blankets and put a 200 watt light bulb under it for the night while in the barn. I can remember farmers building a small wood fire under the engine to get it heated up. No hydraulic hoses etc. in those days to get destroyed.
Fortunately my tractor is in a heated shop. The only issue I have is the time it takes to mop up the melted snow after clearing the driveway.
Bee-Positive
Nov 16, 2022
1,159
1,072
Amsterdam, NY
The diesel cloud point for most #2 is about 14F. Hot Shot anti-gel is good to 20F below the cloud point, so about -6F OAT. I use it and have not had any problems lately even at -15F. Pick your favorite flavor of anti-gel, add it, and be happy. Doesn't do anything to warm up the engine block or associated fluids but it's got to be better than adding gasoline to the diesel fuel. JMHO, YMMV.
I do wish I had a block heater especially with the temps we're seeing currently. I gotta believe it would be better on the engine overall.
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,616
Yes, it's simple, but it cooks the oil and does not do a very good job of heating the block.
Trash Panda
L2501
Feb 18, 2022
287
270
Wyoming
They don’t heat the block, but they do a good job of keeping some temp in the oil. They have made a worlds difference on our caterpillar-powered work rigs in the cold start. A block heater coupled with a pair of magnetic heaters on the oil pan was a game changer, but then again HEUI is a different animal in the cold.
I promise you that a 300 watt magnetic heater with a surface temp of 300 degrees isn’t “cooking” multiple quarts of ice cold oil. It just doesn’t have the power to get the oil up to 300 degree temps that can cause damage to a modern synthetic oil.
Trash Panda
L2501
Feb 18, 2022
287
270
Wyoming
There is quick and there is right!
In a pinch, I’m not above tossing a canvas tarp over a unit, and blowing a salamander heater into the tent I have made.
It ain’t right, but when the wife is about to calve out, I’m finding a way to bust that snow drift open so we can leave for the hospital lol
3,137
Aren’t most Kubota oil pans a cast aluminum material? So magnetic won’t work
