B7510 fluid level check?
chris142
B7510
Jan 4, 2026
71
42
Apple valley,ca
I was greasing the zerks I could find on my new to me B7510 when I spotted a dipstick under the front of the seat.
I pulled it out and there's fluid on it.
But the other equipment I have worked on had a pic of where the attachments are to be when checking fluid levels. This one does not.
I'm sure there is an online guide somewhere but my old phone does not have enough memory to D/L a file that large.
3,563
1,995
Check with the loader down, if applicable, and three-point down. The engine should be off with the tractor setting on level ground.
Always pull the dipstick out, wipe it off, and replace it fully. Pull the dipstick out and check the fluid level.
NoJacketRequired
May 25, 2016
444
Ottawa, Ontario
In case you're wondering, that's the hydraulic fluid check point. It's sometimes difficult to get an accurate reading, so it's best to follow the instructions given above by whitetiger. Seeing the fluid level on that yellow dipstick can be a challenge so make sure you've got good light, too.
