Extra battery terminals
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,563
Searched the forum but didn’t find mention of this.
Found this little gadget for my SD batteries when adding some accessories. They made it very easy to tap off the battery posts. That got me thinking about the tractor. Looks like a winner there too! In addition to the product below, there is an adapter stud to keep the OEM battery clamps shown in the photo in case you don’t want to cut the clamp off and stick the bare wire in a set- screw (which works fine).
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,317
827
under a rock
Pretty Fancy...
I have the "Mil-Spec" type clamps on my truck.
makes it easy to connect aux. cables
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
I bought and installed a pair of the knuconceptz battery lugs on the M5660 when I ran power for auxiliary work lights and a pair of cigret lighter sockets. Exceptionally well-made products.
John T
May 5, 2017
1,317
827
under a rock
But they require the original wiring to be modified, not like the original posters solution where the original wiring stays as is.
ONLY if you buy the optional "top post adapter" for an extra $10.00 each.
either way, It's not a contest Hugo. I'm just pointing out a similar product.
6,293
I see a lot of dissimilar metals in the clamp which allows for easy corrosion as well as 'stuffing bare wire into a hole' is not a good idea( more corrosion). Sure, it'll work 'ok' for a while but once 2-3 drops of water hit it you'll end up with 'funky' electrical problems.
11,757
You need to quit posting. You always seem to cost me money! 😂😂😂
Reactions: 6 users
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,563
Copper, Nickel and Brass are all compatible. Copper and nickel alloys are used in a host of environments. Brass and copper are used together in hydronic plants everywhere.
Set screw terminals (lugs) are also used everywhere. From the electric panels in your house to the AC unit. They are in your electric meter and the high voltage transformers on the street.
I think they’ll be fine on a vehicle.
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,614
True, but if you need to replace the cables (fixing corrosion, or you're doing an upgrade), there is no better way than with military clamps and compression-fitted cables.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Even with metals that play nice together I coat those mating parts with a paste like Penetrox, Cu-Al Aid, NoAlox, etc
lynnmor
B2601-1
May 3, 2021
1,803
1,607
Red Lion
I have a 52 year old Siemens 100 amp panel that has now failed where two breakers connect to the bus, unlike materials. I did cleanup one connection but that breaker was beyond hope. The other connection wasted that bus position. I need to pull all of the breakers, clean the bus and apply a bit of No-Ox-ID. I just added a number of LED shop lights and they blinked, that was my clue about the poor connection, everything else showed no sign of a problem, I'm glad those cheap Chinese LED's saved the day.
chim
Jan 19, 2013
3,278
2,976
A friend of mine had a smoke detector go in the middle of the night because his electric panel was self-destructing. Things DO happen.
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,614
That's not a good thing. Many of those pastes have metal powder in them, and using the wrong one can cause corrosion. There are different pasts for different metals.
JasonW
848
572
Al
I bought the same ones to use on my F250 for an onboard air system. Found them on the Tremor forum. Definitely quality, have used the military style ones also.
Did you upgrade tractors? That doesn’t look like a L2501.
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
Are Knu Konceptz an alternative to wheel weights?
Maybe they're for the big-stereo boys who don't own big crimpers?
There's a lot going on there, and in my experience complexity adds points of failure.
The military style is bulky enough...but will do the job, and for fewer pesos.
Not that I want to go back to hand-crank windows, and they do look cool, just a bit much for most applications.
