PHD Almost Worthless
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
I wonder what the “well diggers/drillers” use in these areas?
I mean, I was not present when my well was drilled/dug, (so I dont know what they used) but according to my neighbors it’s about 290 feet deep.
I would think that whatever they use would work for a 4 foot hole?
Mexicans.
4,211
Mexicans.
This is the local driller and the equpt used by a local family operation.
:I’ve recently watched a commercial driller on the development nearby…and their equip't wasn’t nearly as good-looking…. it was easily 40 yrs old…. when the turn-table engine blew…the truck stayed on-site for a week before a crate-engine arrived…which they replaced in the field.
The crate-engine…arrived in a 1940’s era Air Force container that looked newer than the old surplus engine.
They had that thing running in 4 more days. (They drilled 4 dry holes,…each took 3 days….500+ feet deep and re-filled the holes before moving on to the next dry hole. The general contractor had them give-up …and the developer has contracted with the river-authority to pull water out of the river. They’ll now have to create an entire MUD water-treatment, distribution, sewer-treaatment and grey-water-drip system to supply their “resort”.)
The developer has 3 times asked permission to send a camera down my well to survey it… I told them “NO”. each time. (My well was drilled ca. 1950 and is unrecorded. If I let a driller survey my well….it’ll get recorded in the ground-water-district and become subject to current regulations.)
I don’ think that drilling-rig is economical for post holes.
Bmyers
May 27, 2019
3,634
4,935
Southern Illinois
Thank you! To me a PhD is an education degree...."Doctor of Philosophy"!
That is what I thought and based on the rambling of the post, I figured it was correct since the post appeared to be a philosophical insight.
nbryan
Jan 3, 2019
1,427
946
Hadashville, Manitoba, Canada
Well drillers have huge heavy rigs with rock penetrating tips that have no problem grinding through whatever is encountered.
Another type of portable drilling rig are the granite hole drill rigs used around here in Canadian shield country, for blasting at mine sites, and for installing steel pipes for docks.
They're a whole other class of machine. The diamond tipped pneumatic driven dock pipe rigs are also hammer drills. I have lake ice road dock building experience working with these around, and they're EXTREMELY loud in action.
6,292
curious. Does anyone with 'hard to drill' holes ever use 'hydrovac' system? Around me every new utility pole is hydrovaced. $500K truck is a combination of pressure washer and vacuum systems. Odd thing is 'they' says it's cheaper than using PHD. Don't need PHD to dig the hole, bobcat to load dirt into dump trucks so saves on manpower (wages ) and time.
5,398
Yea I figured they had some sort of "special drill”, but I have never seen one in person.
The only time I have seen a “rock drill” being used was on TV…….(But they were also on an astroid that amazingly had enough mass/gravity to hold them in place so they could drill holes for blasting to save the Earth…...……so my “experience" is fairly limited….:ROFLMAO:)
WI_Hedgehog
Apr 24, 2024
1,129
1,646
I fitted 1/2" PVC to a garden hose to create a "directional boring system." Worked about as good as the professional ones, but for smaller applications like sidewalks. I bet an old liquids tote with electric pump on a trailer would work well for powering a PVC post-hole blaster.
Bmyers
May 27, 2019
3,634
4,935
Southern Illinois
We use hydrovac trucks/trailers all the time at work. More so because we are digging in areas that have underground piping and would prefer not to blow anything up.
jaxs
B1750HST
Jun 22, 2023
1,083
818
As for the original question of how this might be done next time , I'd use drill stem posts welded to plates for the 6 gate posts. I've did it countless times on factory floors and parking lots. Drill holes with conventional masonry bit then set all thread in anchoring cement. Did the same for weld-up buildings when they overlooked to put plates in before pouring concrete. Far stronger than wedge anchors.
6,704
My well is about 550’. 300’ of that is through a solid granite shelf. The rig used a tri-cone roller bit.
5,398
Looks like the one in the movie
Look pricey though…………….I wonder if Vevor makes one?;)
Tim Horton
297
72
Lake Superior
As ...post hole diggers... go I had experience with 2.. First one ..well used.. that took some TLC and cleaned up quite well... Second one was new.. I ran 9" and 12" augers on both.. The used augers I couldn't get new ..hardened.. replacement cutting teeth, so I just used mild steel homemade teeth and sharpened or replaced often.. Both were Speeco brand..
Both worked well..
My 5 cents of experience..
