[SOLVED] Need help finding a hydraulic cylinder wiper
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
565
190
NZ
I'm overhauling the M4500DT's steering booster. I can get most seals from Kubota but not the rod wiper. There's no Kubota part number. The gland assembly containing it is unobtanium (and was USD$900). The existing wiper is munted. There are some tiny letters and numbers on the seal (photo below) but really hard to be sure what they are.
EDIT Sorrysorrysorry the correct OD is 32mm!
I'm hoping someone here can help identify a wiper that will do the job, because I've scoured the internet and so far found nothing.
The current damaged wiper is similar construction to an ordinary lip seal complete with spring loaded lip, but I don't know if this is the correct seal for the job.
Thanks for your help!
6,329
ruger1980
L4310 w/La682, L225
Oct 25, 2020
593
259
CNY
Are they trustworthy?
Yes they are probably one the larger names in the hydraulic sealing component business. I use them and Allegheny York for the most part when sourcing aftermarket seals.
I am not sure who is the best to source from in Ontario but I can ask my colleague that lives in Ontario if he has a recommendation the next time I speak to him.
Old Machinist
May 27, 2024
723
841
NE FL
The last wiper seals I bought for my New Holland backhoe I got from orings and more. Very fast, reliable shipping.
JohnDB
Jun 9, 2018
565
190
NZ
Thanks guys. Sorry, I made a complete tit of myself... the wiper OD is actually 33mm not 34 (got confused with a different seal). I've corrected the drawing.
However based on your input:
@Kennyd4110 @ruger1980 I checked out Hercules, that's easily the best seal finder website Ive ever seen but it doesn't have 33 (or 34) OD wiper unfortunately.
@GreensvilleJay that looks like an ordinary lip seal, I think wipers are more specialised. However, if I can't find any wiper seals I'll look in that direction (s/s spring as per your example).
@Old Machinist Tried O-rings and more, drew a blank there but thanks for suggesting them.
JohnDB
Jun 9, 2018
565
190
NZ
@#40Fan thanks for the suggestion, I've now looked there, huge range but nothing my size (common refrain when I'm clothes shopping too... :)
Definitely metric. The booster seems is so like a Vickers booster design that I did wonder about the possibility.
JohnDB
Jun 9, 2018
565
190
NZ
LoL thanks! Those seem to be rotary seals. I think the wiper seal is a specific design of seal, so I have been hunting in that direction. If I can't find something designed as a wiper, I'm attracted to your idea about a lip seal with s/s spring as a fall-back.
4,042
2,491
That's awfully close to
4,042
2,491
EDIT Sorrysorrysorry the correct OD is 33mm!
That diagram looks like the existing, a spring-loaded shaft seal. That's what I'd use; it's not super important. For some reason 22x33 wipers seem to be extra rare.
JohnDB
Jun 9, 2018
565
190
NZ
Thanks for those suggestions. Definitely not any imperial size. I may have to go with an ordinary lip type oil seal if none specifically designed as wipers are forthcoming.
trevoroni
B6000
May 24, 2023
205
254
I found this part number in my suppliers catalogue but it doesn't show up anywhere else S022033070
I'd go with the closest press in steel/polyurethane wiper I could find.
Here's their catalogue for hydraulic seals. Sealing Solutions
Are you measuring the seal or gland with the dimensions you provided?
#40Fan
670
498
^^ Good question. He sould be measuring the rod for the I.D. and the gland for the O.D.
JohnDB
Jun 9, 2018
565
190
NZ
@trevoroni @#40Fan yes, measured rod diameter 22mm, housing ID 33mm. I haven't given up (yet) on finding a proper wiper seal. Thanks to the input from everyone here, its opened up a much broader range of possibilities so if I can't find anything, it probably doesn't exist.
#40Fan
670
498
If I couldn't find the correct size, but could find the next millimeter smaller one easily, I'd have a ring/bushing made to take up the difference between the gland bore and smaller O.D. seal. That seal doesn't take much, if any abuse, and would easily stay in the ring/bushing.
4,266
This story resembles what occurred to me. My M4700DT developed a leak….and the steering cylinder had been superseded. I ended up having to pay $2K+ for the updated cyl and labor.
Bite the bullet. At least you’ll have a cyl for which parts are available for the future….
