Barbs pumpkin almost ready to go
Jan 3, 2017
45
Boron California USA
Well after 7 years it's almost done I've rebuilt the engine new clutch tires trans paint and decals, I'm finishing up with the hydraulics now had to rebuild all the cylinders had a bent shaft on the right tilt now I have to replace the hydraulic hoses for the loader oh and get a new battery IMG_20251022_214319413.jpg
Reactions: 10 users
4,185
Lovely! Where’s that Loader..??
bird dogger
Vendor Member
Feb 24, 2019
1,790
1,766
North Dakota
OMG!! Well done!! Er....it looks like it will be completely "Well Done" very soon!! :)
Jan 3, 2017
45
Well here's the loader I just got done with rebuilding the hydraulic cylinders it's a woods b206, they were so bad that if you turned them shaft down they just dropped out. I'm going to have to get new hoses these are really cracked. So I have a question my manual says too use 10/30 ms oil in the loader I've been using regular hydraulic oil,has anyone heard of using regular oil?
10,966
Hydraulic fluid is fine to use.
10,966
I've never heard of using regular oil in hydraulic systems before that's why I asked about it thanks Bruce
Bobcat uses motor oil in older skid steers because the oil also runs hydraulic motors and the motor oil has wear reducers.
Stock Woods loaders had black buckets.
5,514
Some of the OLD MOPARs use the engine oil for the transmission I believe so yep
7,200
A modern AW hydraulic oil formulation has those magical anti-wear additives. Typically ZDDP which has the added benefit of being an anti-oxidant.
