L3560 - Easy & No Mess Hydraulic Fluid Change
skipatrol21
L3560LE
Sep 15, 2023
NH
All the YouTube videos and forum threads I’ve seen make a full hydraulic fluid and filter change look like an absolute mess. On top of that, my oil pans don’t hold 11 gallons — so I wanted a cleaner, simpler approach. This is what worked for me, and it was easy and mess-free. Watching people, try and put the drain plug back in to empty out bins, the mess all over the floors, I didnt want that in my garage.
Draining
I used a fluid extractor that hooks up to my air compressor. It took about 10 minutes total, to pull the fluid out, removing roughly 2 gallons at a time and dumping it into a 5-gallon bucket.
After that, I crawled under the tractor and removed the drain plugs. Only about 1–2 gallons were left in the system. I let it drain overnight and ended up with around 10 gallons total, which is close to the tractor’s 11-gallon capacity.
Filling
Most people use a funnel and try to lift a 5-gallon pail — which usually turns into a spill. Instead, I used a transfer tube. I elevated the bucket, primed the line, and let it flow on its own. I went and had dinner, swapped buckets, had dessert, and within about 45 minutes, I had refilled the 10 gallons with zero mess.
Hope this helps someone looking for a cleaner, easier way to do a hydraulic fluid change.
Vlach7
L47 305DT JD500C
Dec 16, 2021
453
330
Frazier Park Ca
You are good, I had nearly 5 gallons of hyd fluid on the floor when I forgot to put my magnets in the new filters.😥
5,577
Good tips! (y)
I haven’r racked up enough hours yet, but when I do, I willl use my “oil sucker” that I use for the boat.
It’s similar to yours, but it has a 12volt pump instead.
It will drain 6 quarts of “warm" automotive oil in about 1’ish minute(s) or so.
skipatrol21
L3560LE
Sep 15, 2023
NH
I bought the Kubota ones, they were more money, but came with the magnets in them.
skipatrol21
L3560LE
Sep 15, 2023
NH
You need License plates for your tractor in New Hampshire
We do if we want to take them on the roads. Plate allows me to drive on any road up to 25 miles from my house. Makes it easy to move the tractor close by then to trailer it. Plus I just drive to the gas station down the road to fill up.
