BX25D Traveling speed
Flyingcritters
B2100, L4580 B25X
Dec 2, 2025
14
23
Gilroy, CA
My manual says the traveling speed of the 2013 BX25D is 0-4 in low and 0-8 in high. I am seeing 0-1.5 in low and 0-3 in high. Any suggestion on how to get the factory speeds?
Vince
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
107
89
duluth mn
Vince
ITS NOT A HOT ROD!
WHY DO YOU NEED TO GO FASTER?
Don
  • Angry
3,557
1,993
Check the ball joints on the ends of your HST linkage. It runs rearward from the HST pedal to a control arm on the hydrostat. The joints can wear out, or the nut securing them will come loose.
Flyingcritters
B2100, L4580 B25X
Dec 2, 2025
14
23
Gilroy, CA
ITS NOT A HOT ROD!
Don
Because something is obviously wrong. Would you drive your car if something broke and it couldn't go faster than 65? For all I know I am damaging the tractor by even driving it.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,095
1,090
E.
Vince
start by upping tire pressure to max. and retesting.
to max. speed while in field you drop tire pressure (improves traction/minimizes slip) on roadways you do reverse you can up tire pressure to p/u ground speed for a certain rpm.
let us know if it makes a difference or you.
  • Angry
3,037
That nut can be the problem - it will back off and you'll lose speed - especially in reverse
Flyingcritters
B2100, L4580 B25X
Dec 2, 2025
14
23
Gilroy, CA
The ball joint looks fine, but the bracket the pedal is attached to has a lot of play on the shaft. I get almost 2" of pedal travel before the linkage starts to move. There is a roll pin through the bracket and shaft, but still a lot of movement. I'll see if I can get it off and figure out why it is loose on the shaft.
Mark_BX25D
Bx25D
Jul 19, 2020
2,095
1,600
Ball joints are not going to account for that big of a difference in traveling speed.
What's your RPM?
stevewhitts
BX25D
Mar 5, 2025
23
31
Maryland
RPM and transmission fluid are the two major factors. With a hydro trans, you need to make sure your trans fluid is full, clean and has been serviced properly.
Flyingcritters
B2100, L4580 B25X
Dec 2, 2025
14
23
Gilroy, CA
Fixed. It was a linkage problem. The tractor would go twice as fast in reverse than forward. I adjusted the speed change rod and now it goes 8mph forward and backwards. Thanks for all the suggestions. BTW, this was my neighbors tractor for 7 years. I used it more than he did but I didn't want to mess with it in case something broke. He decided to sell it so I picked it up. Now I am fixing all the little problems.
Vince
Reactions: 10 users
MapleLeafFarmer
Dec 2, 2019
1,095
1,090
E.
Vince
great to hear and that was a cheap and easy fix.
