BX2200 Transmission Popping Out of Gear
tparsons56
BX2200
Jan 13, 2026
Charlevoix, MI
The rear wheels of my BX2200 have started to pop out of gear in forward high while going up a slope. If I stop, put it in neutral and then back in gear and accelerate slowly it will work again but if I accelerate too much it will once again pop out of gear. It does not do this in reverse, and the front wheels work fine in 4wd. I have checked the hydro fluid and it at normal level. Any ideas? The tractor has about 650 hours.
dlsmith
BX2230, LA211
Nov 15, 2018
1,359
1,059
Goshen, IN
You might check the linkage for wear and to make sure it's fully engaging in high range.
5,281
Every automotive trans I have seen do this, it always ends up being the syncros or the “dog teeth” (internal problems)
Never taken a tractor trans apart, but I would expect similar problems……..
Don’t worry though……actual ‘tractor experts” will be along shortly………. (y)
tparsons56
BX2200
Jan 13, 2026
Charlevoix, MI
Hopefully it is just slop in the linkage as opposed to a trans rebuild. The tractor has been flawless all these years and is my right arm for so many things.
11,009
Anyone have a ballpark number for a trans rebuild?
The price would be a huge variable.
Ballpark minimum $1k
There is not a lot to the range section of the transmission:
Look at this linkage.
When it's in high range does the lever hit the back of the slot?
tparsons56
BX2200
Jan 13, 2026
Charlevoix, MI
I finally took the tractor to our local Kubota dealer but they could not replicate the problem. Once back home, however, I had the same issues.
1. Only happens in forward, mostly in high speed. Does not happen in reverse.
2. The issue is intermittent.
3. More prevalent at higher speeds and on a slope tilted to the right. Also, when the engine is warmed up.
4. When it occurs, the tractor stops moving and I feel a vibration. Once I return to neutral and reengage slowly it will start working again.
5. All hydraulics work as they should.
6. Just changed the hydro fluid with new filter and cleaned strainer. Some metal chips in stainer but not many. Refilled with Super UDT2 but this did not solve the problem.
Any ideas?
tparsons56
BX2200
Jan 13, 2026
Charlevoix, MI
The mystery continues. When I took the tractor to the dealer who could not replicate the problem I had taken off the FEL. Once I got it back I installed the FEL and had the same problem. I just took off the FEL and the problem went away.
What would cause the tractor rear wheels to come out of gear while going uphill with the FEL on?
11,009
Go out and check the PSI in the rear tires, I'm betting they are low and your spinning the rims in the tires.
It happens more than you would ever think possible.
tparsons56
BX2200
Jan 13, 2026
Charlevoix, MI
I checked the tires and I'm embarrassed to say they were very low. Pumped them up to 20psi and the problem seems to be resolved - many thanks!
Both rear tires are loaded and have been repaired with tubes. Now, of course, I have fluid coming from each valve stem unless I park with the stem's top dead center. Not a big deal but see a trip to the tire dealer in the near future.
