Add hydraulic thumb to L35
Doug Alford
B2650
Feb 3, 2024
9
Boone, NC
I have a l35 with fel and backhoe. Also have a w r long third function kit installed. Been using for some time with grapple and other 3rd function
Implements. It is plumbed in to power beyond port. I want to add a hydraulic
Thumb to the backhoe. I would like to use existing 3rd function pump and connect to lines on fel 3rd function hydraulic ports. I know I would need to put a hydraulic relief valve to equalize any pressure between bucket curl a d thumb. I have a joy stick 3rd function control on fel control arm. I was planning on adding another joy stick control on a backhoe control arm by tapping into other joy stick wire. Does anyone one else see any problems or a better way?
11,121
You are 1000% over complicating this!
There in no third function pump?
The third function would not need any additional hydraulic relief added to run the thumb.
Why don't you just add a spool valve for the thumb?
Much simpler and a lot less hose draped across the tractor.
Doug Alford
B2650
Feb 3, 2024
9
Boone, NC
Thanks for your input. So I am not familiar with the spool valve. Where would lines from hydraulic cylinder on thumb be connected to? And how would you control the hydraulics to thumb.
3,104
Look at adding a new valve into the backhoe hydraulic system. But keep the backhoe valve as the last one in the circuit before the return line to your tractor.
11,121
A spool valve is a control valve that would run the thumb.
The cylinder would connect to the valve.
Call Summit tell them what you want to do and they will set you up.
3,934
2,435
* Here's a way to add a section to the valve stack. Using this method everything is mechanical, no electrical wiring, and the thumb is controlled by your foot. This is the method used by Kubota. @RaleighL35 got lucky finding the valve section cheap.
* Your proposal will work.
* If I ever add a hydraulic thumb to replace my manual one, I'll probably add a solenoid valve and buttons on one joystick. If you do this, the new valve must be before the existing valve stack in the hydraulic loop. This is to prevent exerting too much back pressure on the tank circuit of the existing valve and damaging it. This method does require adding an electrical connection to supply power.
3,934
2,435
I used a Titan weld-on kit for my manual thumb. I think a thumb that pivots on the bucket pin (extended) would function better. Does anyone know if a thumb and pin from a BH92 or other would fit the BT900?
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
Is this something I could use on my L47 for a BH thumb or with my forks if I were to make an improvised grapple? Doesn't sound like I have a Power Beyond.
11,121
You have PB at the loader and possibly other places too.
It's not to hard to add a spool valve.
The post that @PoTreeBoy pointed to, is really good!
That would be the best way to do it if you can round up the parts.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
606
622
Lake Almanor, Ca
Do it OP!
The best thing I have on the tractor as I am in a rock infested part of the world. Added a valve to the plumbing and has worked great for 15 plus years. My lines are carefully routed/hung to avoid pinching and getting caught. Looks lame but works for me. IMG_1417.jpeg
