Bush hog blade blues UPDATED WITH PICTURES
5,529
A little hard to tell from pics, but the key on the new bolt looks a bit thicker than the key on the old bolt. You sure the new bolt key is seating correctly in the carrier slot?
2,587
I personally don’t remember how much movement like that was left in the blades.
But I will check mine out on Wednesday and post back some information then.
Are the blades upside down on that video? I get all turned around looking at stuff in videos so will also look at mine on Wednesday!
9,939
Ok got it:
The nut is bottoming out on the shank before its tight!
(Purple lines)
Put a hardened thick flat washer under the nut.
texican
L3000F, FEL
Oct 12, 2023
102
22
East Texas
hopefully you are on to something. I measured the keys up and down..let me check on width when I get home. thanks
texican
L3000F, FEL
Oct 12, 2023
102
22
East Texas
I think youre right..i need to run the original bolt up in it without the blade and then new one and see what i can see. will be a week before I can get out there..thanks
Elliott in GA
Mar 10, 2021
837
848
North Georgia
It sounds like your problem might be solved with a washer or two, but if you decide you want a torque multiplier - watch this Torque Test Channel video.
Significant performance variations - both power and accuracy.
Fastball714
L4060HSTC, B3300SU
Feb 27, 2021
44
47
Georgia
The bolts are both 3/8 at the bottom, but were the blade sits, one is 7/16 and the new one is 1/2'". I think the new bolt is wrong for the blade.
9,939
The new blades are 1/2" ,old blades were 3/8.
So the new bolts match the new blades.
2,587
I remembered to look at this today and the tip of the blade is free to move 3/4 of an inch from full down to full up, when fully extended out like it is during operation.
The blade is about 3/8 inch thick and 18 inches long.
The bolt has about a 7/16 inch long shoulder for the blade to sit on (shown below).
The blades and bolts are OEM from Modern Ag
