Trustable
l2501HST
Jul 5, 2022
397
411
Cleared more snow. I cleared probably 7 inches yesterday evening but the wind just brought all the snow from the lower areas of my property and neighbors properties to my driveway and front door so I had to do it all again. Can’t wait for that snowblower!
I also took the Pats QH off and bagged all the hardware related to it up in preparation for the landpride QH16. Even found the original bag with extras and manuals it came with. Maybe Ill list it on marketplace - every time I have tried to sell something on there it’s just people wanting me to hold it and then never contacting me again or just wanting it for half off. IMG_4459.jpeg
I forgot how much of a pain it is to attach the back blade I have without some sort of quick hitch. It falls over forward no matter what so I’m trying to lift it up with a car jack and position it perfectly for the lower 3pt arms. I need to see if harbor freight has a cheap trailer jack that I can bolt to the attachment to keep it upright when not on the tractor.
ajschnitzelbank
Aug 24, 2021
271
700
Rensselaer County NY
I’ll add it was the first time for ME pulling them out this winter, but not the first for them! The tow hook in the front bumper was broken off. The hole where it threads in was plugged with the broken off threaded bit of the hook.
Reactions: 6 users
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
154
299
Mark Twain Forest
Past two days had 60 deg weather. Dug out the 8'x8'x3' container gardens, mixed the dirt with leaf compost, filled the gardens back in with layers of kitchen compost.
Then put the new Edge Tamers on the buck in preparation for the polar plunge blowing in.
g_man
Feb 3, 2023
384
1,792
NE Vermont
I finished up pulling out our wood for 2027/28 yesterday. One of my targets for firewood is junky Beech like this one. It's just above a tractor road - easy access.
Leaning left but I wanted it to go straight across the road.
Had trouble getting the choker under it even though there was a pin on the chain. The choker puller did the trick.
Cut the tree in two, then winched in the butt end down into the road.
Then winched the upper piece up beside it and winched them both to the tractor. I left some limb wood to pick up later.
Skidded them to the landing and added them to the pile.
I'm never really done with firewood but I have enough for now. The goal is to have this worked up by the end of mud season. That gives two summers for it to dry - one in the sun and air and one in the shed.
gg
Reactions: 13 users
Trustable
l2501HST
Jul 5, 2022
397
411
Snowblower and QH were delivered! The guy also had a big 50hp kubota excavator on the trailer too, and wow that thing is quiet compared to my l2501. I already tried it out and had the deflector facing towards the wind and learned why people like cabs 😆. But regardless I’m excited to use it more, just gonna have to put a ski mask and goggles on.
Reactions: 6 users
biketopia
Feb 15, 2024
432
467
Warrenton VA
gg
I think you've posted how before. How do you store your stacked wood if you're moving from not covered to covered?
forky
Feb 23, 2021
350
390
Wisconsin
Which model did you purchase? Keep us posted how happy you are with it after a good snowfall.
Old_Paint
Dec 5, 2020
2,038
2,307
AL
I also took the Pats QH off and bagged all the hardware related to it up in preparation for the landpride QH16. Even found the original bag with extras and manuals it came with. Maybe Ill list it on marketplace - every time I have tried to sell something on there it’s just people wanting me to hold it and then never contacting me again or just wanting it for half off. View attachment 168182
I have a quick hitch, and I will say without reservation, I feel like it was a mistake. Not so much because I bought a cheap one, but more so because of how difficult it makes connecting a driveshaft on anything that requires one and the complete lack of compliance to standards to make "QH Compatible" actually mean something. Especially my chipper which is HEAVY and very uncooperative about the shaft anyway. I have to be a contortionist to connect the driveshaft after connecting it to the lift. HOWEVER, I did find that it's much easier (but not easy) to connect the shaft to the PTO before I get too close to the chipper. The frame for the three-point connection on the WC68 combined with a quick hitch leaves all but NO room to access the PTO shaft because the hitch and the top link. I can only imagine it would be doubly worse because of the cylinders and hoses if you have a hydraulic top & tilt setup to go with the grader blade.
You're on the right track to put a prop on the blade, but I'd probably do something a little less expensive even than a jack. Personally, I'd just cut a 4x4 the right size to hold up the blade 3-point frame up or even build a wooden prop frame for it that I could lift the blade over and drive away. That's the cheapest solution I can come up with, and I'm as stingy as they come.
If I had it to do again, I'd probably go with the Pat's Hooks instead of the QH. I do like the convenience of the QH for things with no drive shaft or tool props, absolutely. But my chipper is a bear to connect with it on, and I find myself still getting off the tractor to stow the props on anything that uses the QH and has to be propped up. I can't use it with the hole digger because the boom replaces the top link anyway. And again, no way would that driveshaft even think about working with the QH. On the other hand, it would be a lot easier to attach the PHD with the Pat's Hooks (than having to insert the pins in the lift arms), and not much more trouble (getting off to connect the top link and/or driveshaft) on other attachments. In addition, the QH really doesn't help unless you take the time to park the attachments on reasonably level ground and all of them have approximately the same requirement for top link length. A Top and Tilt Kit can help with that issue considerably though.
I'm not telling you that it's a bad idea to switch to a QH, I'm just relating my own experience with Quick Hitch Compatibility, especially a Cat I QH that someone got very confused about when they designed it. I got a Cat II QH because I have the LX2610SU because the geometry of the 3 point hitch on the LX is Cat II. Personally, I'd advise against the QH and put the Pat's hooks back on. The HF cheapo (like I have) has Cat III hooks on the bottom pins, and a Cat 2 top hook. The Speeco has Cat I toplink, and Cat II bottom hooks. It's anyone's guess what category pins will be put on an attachment. It isn't a single attachment that would make me decide that, but more the extra work and modifications I had to do to make them all fit the same hitch. I also had to modify my QH to make it connect gracefully to my attachments, because it just seemed to be more aggravating than manually connecting each point. The bottom hooks were really bad to hang on framework at the lower pins, or even on the pins themselves because of the flat tops and sharp corners. So I tapered the top inch and trailing edges of them which didn't harm the load capacity at all, but made the QH center itself better and the attachment pins slide into the bottom hooks much better. I have some photos posted in my gallery if you want to look. It took a few cut-off disks to hog off the corners, and then some work with a flapper wheel to round the remaining corners, but it made a world of difference in that QH. At the time, all I had was the BB, and a sub-soiler. Turns out the subsoiler wasn't QH compatible at all because the top link pin hole was about 3 inches too low for standard Cat I spacing, and the top of the frame had a piece welded in it that interfered with the QH top hook. That meant I had to take the QH off to use it. What's the point in having a QH if it won't work with ALL of the attachments? So I looked up the geometry for Cat II spacing and did quite a bit of work to the subsoiler so I could use it on the QH. I also had to modify my tow bar because it was a Cat 1 bar, and wasn't near wide or tall enough to fit on the QH. None of these issues would have been a problem if I'd got Pat's Hooks to begin with. The only attachments that I have that don't require I get back off the seat at least once are the subsoiler (sitting in a homemade wooden perch) and box blade, both of which I modified based on compatibility with the QH and Cat I/II specifications.
Bottom line, I think you'll regret taking the Pat's Hooks off. I don't know how many attachments you have, but you'll learn very quickly that "QH Compatible" means different things to different manufacturers and you'll miss those Pat's Hooks when something has even a half inch of difference in spacing. Don't even get me started on some attachments having Cat I pins and others having Cat II pins and the bottom hooks on the QH having Cat III hooks. I have a pretty good assortment of bushings for all the different combinations now. I have most of my attachments adjusted for QH compatibility now, but it took some work and some hardware to make that happen. Even some welding on my subsoiler and tow bar. It's quite frustrating to have to remove the QH for some things, and then put it back on for others. If I were a younger stronger man, yep, I'd do without and just manhandle the pins in place. But I like the ends of my fingers right where they are and I can't count the times I've been pinched attaching something to a tractor.
Just be ready for the normal headaches that come with "QH Compatible" claims. If I lived about 600 miles closer, I'd be knocking on your door to buy those off ya, but I can get them (or equivalents) with no shipping cost by ordering online with a 15% discount and having my wife pick them up when she leaves work. Wouldn't make sense to even try to negotiate a price with you.
Old_Paint
Dec 5, 2020
2,038
2,307
AL
Why the two styles, is it a set, or just showing two different styles?
My guess is one bolts on the bucket through a hole and the other just clamps on the edge. At least that's what it looks like to me.
Trustable
l2501HST
Jul 5, 2022
397
411
I appreciate the feedback! The only PTO powered attachment I have now is the snowblower, I really don’t have plans to get anything else that’s PTO powered to be honest. Thankfully I don’t have a lot of attachments, the only thing that’s not going to fit is my homemade weight barrel, but I left enough room to drill additional holes in the top link support. The QH I got has I believe 8 inches of adjustment at the top link. If I had more of a variety of attachments I would probably have left the Pats on, but I have 3 total attachments that fit and 1 that I need to modify. With the PTO, I hear ya, today the delivery guy helped me hook it up and it was not fun, but that’s more because of the grease being not very pliable and us being on a hill. I think it’s gonna be a pain for me to do no matter what until I get used to it. I am going to keep the pats for now because of your comment, in case the quick hitch isn’t for me, or at least for a backup.
Trustable
l2501HST
Jul 5, 2022
397
411
It is a SB1064 with the hardened bolt on wear edge and skid shoes on the sides. I got the manual adjustment for chute and rotation, as I don’t have rear remotes. I have some snow on a pathway to a shed at my place so I’m gonna see how it does with that! I can already tell you it’s going to save me hours of trying to move snow from the edge of the driveway after plowing with the back blade. I’ll post another update when we get more snow. Hopefully we do, now that I have one.
Old_Paint
Dec 5, 2020
2,038
2,307
AL
Yeah, the Pat's Hitches offer the flexibility of leaving the top link out of the way until the driveshaft is connected. Not an option with the QH. I'm pretty tall (6'1") and have arms like an orangutan, but they're still not long enough to reach that PTO shaft. I have the fat tires on the LX, too, so that's even more stuff in the way. I certainly learned the hard way to research the different options more.
If I use the Pat's Hooks on the LX, it has the telescoping stabilizers which means I wouldn't need the spacer rod between the lift arms. I've been eyeing them for about 2 years now, even more so since I bought my flail mower which is not QH compatible at all.
You have a tractor, who are you kidding with "I don't have plans to get anything else that's PTO Powered"? That's tractor blasphemy. It's amazing how many more things you'll find you "need" the longer you have a tractor.
Trustable
l2501HST
Jul 5, 2022
397
411
Yeah I never thought I would need a snowblower but here we are so you are right there!! I would definitely recommend the pats though in your case, they seriously make it so easy when compared to trying to fit the attachments in the eyes.
g_man
Feb 3, 2023
384
1,792
NE Vermont
It is green when I work it up so it dries quite a lot if just left in the sun and air uncovered. Rain just wets the surface and dries off quickly in the air. The species I have season well. I don't have species like red oak that take much longer to dry. If I split it on the landing I just make rows spread apart enough to weed-whack between. Even wood that I split in the woods and trailer home dries enough when left in the trailer. The second summer it is in the shed with ventilated sides to finish drying.
gg
Reactions: 9 users
